Question about MagLite Mag-Lite& Flashlight
Flashlight does not light up. batteries are new and bulb is new.
    New Friend:
  • 50 Answers
Check the continuity of the bulb.. also check the contact maybe it is already rusty
Posted on Oct 14, 2010
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Our flashlight stop working even with a brand new battery
The bulb may be blown. If the bulb is ok then you may have a broken wire, corroded connections or a bad switch.
Jul 20, 2014 | Eveready 6V Super Heavy Duty Lantern...
The flashlight won't turn on even though it has new batteries.
Check the bulb. Unscrew the light to inspect the contacts for the batteries and (as possible) unscrew in a place you can check the contact points for the bulb, switch and bulb. A simple cleaning with a contact cleaner, WD40, dry wool or as possible a blade (knife).
Mar 24, 2012 | Inova Camping, Backpacking & Hiking
New batteries, bulb looks fine, no light-what gives
hold the glass part of the bulb, and twist the metal base. there may be a break there. good luck, hope this helps.
Nov 06, 2010 | MagLite Mag LiteĀ® 2x 'd' Battery ...
Keeps blowing new bulbs
Since this is a simple construction flash light (no electronics) make sure you are installing the correct bulb for the voltage of the batteries.
If you use a bulb that is for a 2 cell (3.0 volt) in a flashlight that takes 4 cells (6.0 volt) the bulb will burn out every time.
Oct 15, 2010 | MagLite Camping, Backpacking & Hiking
Have put new batteries in bulb is ok just stopped workin 5 cell dd batts
First of all are you certain the bulb is ok? Test for continuity across the light bulb. The filament in light bulb will have a very low resistance. if you are not handy with a multimeter then respond back with a new thread and I can give you more tips on using a multimeter.
Next, clean the contact surfaces off where the battery terminals contact the flashlight copper contacts. You can use a high grit sand paper if necessary. They sell battery terminal cleaner solutions/supplies at Automotive stores if you like. However, distilled water and/or alcohol will probably work just as good.
Next connecting one probe of your multimeter to the top inner contact and then the other probe of your multimeter to the lower inner contact turn off and on the switch. When the switch is on, you should see the same resistance that you checked the resistance of the light bulb filament.
If you don't see the same resistance then switch is bad.
If resistances are equal then place batteries back in flash light and everything should be good to go!
Aug 04, 2009 | MagLite Flashlight Type: Black D Cell 5:...
Change bulb light will not turn on
Try getting a new battery, and see if that works.
Jan 01, 2009 | MagLite RX3019 Rechargeable Flashlight...
MagLite Mag-Lite& Flashlight Logo
49 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
