Question about Microwave Ovens
Can I mount an over the range microwave below a soffit that is above a range in an island? There would be no wall to mount to - could a surround be built?
MicrowaveSvc
  • 9047 Answers
SOURCE: Removing Microwave
First I would wonder if you really need to remove it from the wall? Many repairs can be done with it still in the wall. If so, installation instructions should be with the paperwork that came with the oven, and that will show you how to remove it. Buit if you don't have that, you would likely remove the grille from across the top. The grille is usually held in place with screws and/or clips. After that is out, there may be a couple of other screws now revealed at the top edge, or there may be a one or more "catches" just under the top edge of the the chassis. I would strongly advise you to have a helper working with you. These can be heavy, and awkward. You might call the GE Answer Center and ask if they can supply you with installation instructions. They're at 800-626-2005 (24 hrs.) Otherwise, you may be able to find instructions that are close enough at a place like Lowe's. They may have some demo models and you can usually ask to look at the manuals.
Posted on Jan 07, 2007
MicrowaveSvc
  • 9047 Answers
The installation guide will show you how it is installed and you can download that here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%204358149.pdf
If that link's a problem, just look it up under the Owner Center section here: http://whirlpool.com/custserv/index.jsp
Posted on Nov 26, 2007
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
  • 95 Answers
SOURCE: Whirlpool microwave, intermittent blower activity, shuts down microwave
Not clear what to explain but would look at the front control switches, commond problem, to see just play with the door open and closing to see what happen's with the fan, it's probroly not making proper contact, the other problem I can thing of is bad thermal heat sensor, there should be two or three of them, you need to know the basic what they do to test them just jump them, and try the unit and see if the problem stop to see witch termal is deffective.
Hope this help
Bob The builder
Posted on Feb 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: removing microwave surround
Ahh, that's one of those British brands I can't get any information about.
If you have the installation instructions, they would tell you how to install it, and it's as simple as reversing the procedure.
BUT maybe it's not too different from US models in the sense that many of its components can be accessed without pulling it from the wall, assuming it's the over the range type.
I would first refer you here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
In most cases, you unplug the oven, then remove the vent grille across the top, then you'll see a screw holding the top of the control panel frame in place.
Once that screw is out, you probably lift up and either swing forward or twist to loosen the control panel.
You should be able to access the fuse, etc. at this point.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If it's built into a cabinet, then you would have to remove the metal frame covering the area in which the microwave rests.
Be safe.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 26, 2008
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Installing microwave in center island
hang on..let me see those installation instructions from Tappan's site..back in a minute
Feb 29, 2008 | Tappan TMS062E1 Microwave Oven
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
How do I remove a 1991 Roper over the range microwave. There are no cabinets above it that it would be screwed into.
If it is not mounted above, it is most likely attached to a mounting bracket behind the microwave. I would start with removing the vent cover (if there is one) and check for access to screws or bolts on the back side of the microwave. Make sure that you have a friend helping!
Some other tips:
http://www.ehow.com/how_4452966_remove-wall-mounted-microwave-oven.html
Jul 25, 2014 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Who makes a microwave oven that mounts in an
Why can't you use the wall plate? Even if you had to use construction adhesive it would be better than nothing. If you are installing in an island setting then you will have to reinforce the cabinets as they would have to support the weight of the micro.
Eric
Oct 01, 2009 | Microwave Ovens
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
