Question about Danby DCD5505W Electric Dryer
Model dcd5505w-1 where can i get parts, im in need of the part that holds the door shut
    Problem Solver:
  • 87 Answers
Contact Danby
Posted on Oct 14, 2010
How do you take apart a Danby Designer dryer to replace the belt?
INSTRUCTIONS TO CHANGE DRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF THE FRONT THAT GO FROM BOTTOM UP
REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT REMOVE THE FRONT SCREW FROM THE CENTER BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP
REMOVE THE 2 SCREWS ON EACH SIDE AT THE TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT REMOVE THE 2 SCREWS ON EACH SIDE OF THE INNER BULKHEAD PANEL AND REMOVE THE PANEL AT THIS POINT YOU CAN REPLACE THE BELT,
IDLER, AND MOTOR MOUNTS THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
May 11, 2010 | Danby DCD5505W Electric Dryer
Here are the Danby instructions: First Make Sure that Dryer is Unplugged from outlet.
THE FRONT THAT GO FROM BOTTOM UP. REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREW FROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACH SIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVE THE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THE BELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Mar 19, 2010 | Danby DCD5505W Electric Dryer
Won't start
if the door is not tight as in you can move it slightly when its closed,the door strike and door catch need replacing and can be done without dryer disassembly at the front door,open the dryer door and in the lower right hand corner theres a small plunger switch push this in with your finger you will hear a click,then start dryer with door open being careful,this test will rule out switch problem,then just replace door parts
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
Oct 31, 2009 | Danby DCD5505W Electric Dryer
Danby dryer has stopped spinning
Here are the Danbyinstructions:
INSTRUCTIONS TO CHANGEDRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF
THE FRONT THAT GO FROM BOTTOM UP. REMOVETHE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK ANDLIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THATHOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREWFROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACHSIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWSAROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVETHE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THEBELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THEBLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Feb 15, 2009 | Danby DCD5505W Electric Dryer
Dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Oct 30, 2008 | Danby DCD5505W Electric Dryer
Is it dead
This could be caused by different things: Does it make a motor running sound when you try to dry, but the basket won't turn? If so, it's probably a broken or jumped belt, which would require a fairly extensive disassembly to repair.
But It can also be caused by the "door closed" interlock switch, located somewhere in the door frame area, usually activated by a pin-like or tab protrusion on the inside door facing. Make sure the door is fully closed. If still no go, try and locate the switch and actuate it externally with a toothpick/straw (or anything that approximates the protrusion on the door that normally works it) with the door open and try the start button again. Still no joy, jumper the switch terminals to bypass the switch and try again. If it goes now, then it is a bad door switch.
It could also be a bad start switch, bad motor, or bad connection in the wiring to the switches, timer, and motor. All of the above require some disassembly to get at the components, and a Volt-Ohm Meter (VOM) woul be invaluable in locating the fault.
Dryers are fairly simple devices compared to other things, but the addition of programmed features has made them a little more complex, but once the component functions ae understood, they are not difficult to diagnose and hopefully repair. The biggest obstacle is learning how and what order to disassemble to access the parts,and then get it back together again in a proper fashion.
Hoe this shed some light on your problem and gives you some ideas to try. Good luck!
Jun 06, 2008 | Danby DCD5505W Electric Dryer
Hello....
I needed to replace my belt. I called the Danby Customer Service number 1-800-263-2629. I called early in the morning and got straight through. I received wonderful, prompt friendly service.
The belt cost $25.19 plus postage and handling.
Joe
Jan 16, 2008 | Danby DCD5505W Electric Dryer
Door Handle Broken
yes contact your local appliance dealer or if you have the manuals that came with this dryer contact the manufactuer by the listing on thier literature.
Or do a web seach LIke :DANBY DCD5505W DRYER PARTS
Jan 15, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
205 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
