Question about GE WBVH6240F Front Load Washer
Has anyone determined what the drum bearings are (where they can be bouhgt) for the GE front load washer model WBVH 6240F? GE wants to sell the entire rear drum assembly for seeral hundred dollars to replace these, but others have been able to replace their bearings on non-GE front loaders. Also, are the bearings (and rear drum) in common with a particular Frigidaire model? Thanks Bob
    Problem Solver:
  • 87 Answers
Maybe contacr GE, u idiot
Posted on Oct 14, 2010
GE front loading clothes washers model: wcxh208h2ww --during spin cycle is incredibly loud--like a freighttrain going by--anyone have an idea for issue/fix?
Sounds like your bearings have failed - possibly just worn out after much use.
You can usually verify that this is the case by checking the play, the amount of movement, in the wash drum by trying to move it side to side (left/right) or up and down through the front door.
Generally they don't move at all, not even a fraction if the bearings are 100% OK
If you have a reasonable aptitude for DIY and are quite mechanical minded, replacing the bearings yourself is very possibly presuming you can get a new set.
Otherwise you need washing machine repair man
Apr 02, 2017 | GE Washing Machines
How do I replace the bearings holding the drum
Google how that model. How do you know it's bearings? could be
rollers holding up drum or the drive belt.
Sep 29, 2014 | GE WPXH214A Front Load Washer
Have a GE front load adora model WHDVH626FWW - loud banging noises while spinning. I have checked the belt and it is fine. Drum is loose - how do I get the drum out to see why?
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | General Electric WHDVH660H Front Load...
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
The whole drum assembly in my ge front load washer is loose and banging
Sound like the bearing on the back of the drum has failed. It's not too difficult to replace.
Sep 10, 2012 | GE WBVH6240F Front Load Washer
My GE front load washer is thumping when the washer basket is at a specific spot in the spin. It sounds as if something is hitting in between the washer basket and the drum at the lowest part. I can turn...
first watch the drum as you rotate it,if it runs out of round,its not the bearings,but the spider on the back of the drum that holds it on the drive spline,if you notice strips of plastic in the pump this is a good sign of a bad sapider,dont use as if this shatters it can throw the tub out,call g.e. and get a recall on the tub,i got a customer a full refund on a g.e. like this and a new washer call them dont use for your safety
Jan 01, 2011 | GE WSXH208A Front Load Washer
How do you replace drum bearings on a GE front load washer?
you can not. must replace entire rear of two piece drum that holds bearing. might not be worth time and costs!
Sep 28, 2010 | GE WSXH208A Front Load Washer
The metal tub has come loose within the housing. It was making a terrible noise. I looked inside the door and the stainless steel drum is disengaged. The rubber gasket and all is fine. Model #...
Two possibilities, one that the drum broke off of the supporting shaft--very expensive part (but could possibly be welded) and a complete tear-down to fix. The second is that the main bearing just behind the drum is bad. You can replace the bearing--go to a bearing supply house with the old one--cost less than $20, plus full tear-down to remove and replace. We went the bearing route and years later is still working well. If you try to buy parts from GE, they want to sell you the whole outer drum assembly for many penny.
Sep 18, 2009 | Washing Machines
Machine stops on it own
Take the board out and flip it over and check the r11 resistor. It is usually burned out.
Nov 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
GE WBVH6240F Front Load Washer Logo
394 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
