Question about Whirlpool Washing Machines
My Whirlpool Duet Model No. GHW9100LW2 won't start. All the indicator lights are functioning, but the time is flashing and the "hold to start" button won't start it and the "cancel" button won't stop it.
    Sergeant:
    Champion:
  • 271 Answers
Achually it is started and working Fine but...there is a belt (like a fan belt in vehicle) Which makes the connection between the drum(which you put clothes) and the motor...
When this belt is worn out (usedup) The belt goes on slipping...so the motor makes the spin but it is no taken to the drum...
This kind off things cannot be detected by the machine
This belt also can be broken...You have to change this...
Changing this is not so hard...unscrew the rear part...there you will find this belt...remove it...and take it with you when you going to bye a new one...
PLEASE RATE ME AS "FIXYA" <blue boxes> for my help
Posted on Jun 02, 2008
    President:
  • 2,712 Answers
Firts try a hard reset: Unplug the washing machine from the AC source,and turn of the circuit breaker for about 10 minutes. After 10 minutes, replug the machine and turn on the machine and see if it works.
  • Swilin Sampson
    Swilin Sampson Jun 02, 2008
    I that does not work, Press the end of cycle signal - button for exactly 3 seconds. That should work.
    If it does not, it could be a faulty control panel /wire harness/ motor. I would recommend getting it checked by a competent repair guy.
    Hope that helps! If you found my solutions led you to a fix, kindly take a moment to "Accept" my solution. Thanks in advance,
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 03, 2008
    Just wanted to inquire if you have had any luck with the machine? If not, please post back as what steps you took, and I will try to assist you further as best I can..
    Sergeant:
    Champion:
  • 347 Answers
Lol, what kind of responce is that?
Cherly, i can help you trough here, but, I cant find your product, Is it one of these whirlpools?
http://www.whirlpool.com/catalog/category.jsp?cat=115
  • 725 Answers
I can help just chat with me..
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
Model #GHW9100LW2. Control lock light is on and i do not have a manual. How do I turn off the control lock so I can run the machine?
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however, your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool Washing Machines
Ghw9100lw2 Duet washer will not drain or spin. was flashing a "F" on the display...
remove the lower panel on the machine and you will see the water pump and right next to the pump you will see a drain plug --- turn the plug counter-clockwise and unscrew it. let it drain,, and clean out any blockage that may be in there. after it is clean,, re-install the plug and start the wash cycle,, this should solve your problem.
if you are still having troubles - please feel free to write me back here,, Ii will do my best to walk you through any steps needed.
c...
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET WASHER MODEL NUMBER GHW9100LW2?
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Control/Locked light stays on Model GHW9100LW2- cannot use washer.
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, be the first to rate me good!!
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model number GHW9100LW2,SER# CSR2021497
Central Control Board part 8182221. You can go online repairclinic.com to order parts.
Good luck
Jun 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
