Question about Dryers
The belt is squeaking and has come off and I need to put it back on. There is also some type of spring that needs attached somewhere
  • Dryers Master
  • 7,482 Answers
It is an idler pulley and it attaches to the bottom main frame.
Do another thing and check your rollers....
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 14, 2010
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Serpentine belt tore while driving bmw e38
The top small pulley backed it's self out. The problem is in most cars the pulleys are reverse threaded so this wont happen, in ours not so much. The pully spins loose with the turn of the belt so it has to be tightened way down. IT's a pain. Here is a diagram I found and You need a 15mm wrench, which doesn't just come in most sets. Good Luck
The book says "Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise. Make sure spring keeper engages into slot." I would put a socket on the 15 mm pulley bolt and a long handle for leverage. Thats one tight spring.
Oct 12, 2012 | BMW Cars & Trucks
How do you tighten AC fan belt
i have 96nissan pathfinder and belt squeaking when i start the engine and stop and start squeaking when iam driving and stop and come back it a new belt
Jun 29, 2012 | 1996 Nissan Pathfinder
On the 2004 dodge ram 5.9 diesel. Do I losen the tensioner ?? I thought it said to remove it. I lossened it. Not sure how tight to tighten it back ? Now I have a squeak. Not sure if the tensioner is lined...
most tensioners are spring loaded. you put a socket and a Johnson bar (as we used to call it) on the pulley and turn the pulley away from the belt so you can remove the belt.
As for the squeak, try some belt lube
To re-tighten the tensioner, you may have to loosen the mounting bolts and put some type of pry bar between the mounting bolt assembly the put downward pressure on it and tighten the bolts.
Feb 12, 2011 | 2004 Dodge Ram 2500
Noisy
The belt is called a 'Serpentine' belt. Named for the way it winds in and around the pulleys.
Before proceeding, look for a diagram (Under the hood somewhere) of the routing2.gif for the belt. If none exists, draw a picture. This will help you putting the new one on.
Anyway,this single belt is held tight by a spring loaded tensioner pulley. Itwill be a smaller one, attached to an arm, not a pump or anything.
It'sthe arm that is spring loaded. The tension on the belt is relieved bythe controlled application of force on this arm. Nothing needs to beremoved, no pry bars are needs
There are different types,requiring different tools. Look for a 1/2" square hole on the arm. Ifthere, you'll need a 1/2" ratchet or breaker bar. A short extension too.
If not, you'll need a socket that fits on the nut of the pulley. Plus the ratchet.
Set the ratchet so it extends upward, above the engine.
Positionyour self to be able to move the arm one handed and still not hityourself in the face if it slips. Push (or pull), slowly building upuntil the belt is loose enough to to slip off of one of the otherpulleys.
Then slowly release the tension on the arm.
Putting the new one on is pretty much a reverse of this procedure.
From your description, I gathered you wanted to replace the belt. If it was the idler pulley, the belt still need to come off.
At this point just loosen the nut on the pulley and replace it. Then put the belt back as described.
Hope you find this to be very helpful
Best regards,
Mike
Nov 13, 2009 | 1993 Nissan Maxima
I need to replace a drive belt for a 2001 AU. Do I take the power steering pump off to do this??
Hi Serena,
No. There is what is called a serpentine belt on the Taurus engine. WE ARE talking about a Taurus aren't we?
Before proceeding, look for a diagram (Under the hood somewhere) of the routing for the belt. If none exists, draw a picture. This will help you putting the new one on.
Anyway, this single belt is held tight by a spring loaded tensioner pulley. It will be a smaller one, attached to an arm, not a pump or anything.
It's the arm that is spring loaded. The tension on the belt is relieved by the controlled application of force on this arm. Nothing needs to be removed, no pry bars are needs
There are different types, requiring different tools. Look for a 1/2" square hole on the arm. If there, you'll need a 1/2" ratchet or breaker bar. A short extension too.
Position your self to be able to move the arm one handed and still not hit yourself in the face if it slips. Push (or pull), slowly building up until the belt is loose enough to to slip off of one of the other pulleys.
Best regards,
Mike
Oct 18, 2009 | 2001 Ford Taurus
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
I have a 1990 audi 200. When accs. turn on alternater belt squeak
I agree. Replace the battery first. It's under the back seat, which will lift up after undoing two screws in the front of the bottom of the seat. Remove negative terminal, remove positive terminal, lift old battery out, put in new one, attach positive terminal, attach negative terminal, reinstall seat, and you're done.
If that's not the issue, you may need to replace the alternator.
Feb 19, 2009 | 1991 Audi 200
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
