Question about Coleman Powermate Premium Plus 6250W Portable Generator
Colman powermate pm 1500 ..no ac power ..runs ok but no ac power were should i start to look or test ...
2 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Colman powermate PM 1500
You could have a shorted diode in the full wave brige for the DC charge circuit, test it with the diade scale on a DMM.
Regards,
Carl
Posted on Mar 01, 2009
HOW DO I USE THE 240 CORD THAT CAME WITH MY 5000W. COLMAN POWERMATE
It is a twist-lock plug, just push it in and turn to the right. Link to the manual:= http://www.powermate.com/pdfs/2007/11/17/manual_pm0435003.pdf
Jun 13, 2011 | Coleman Powermate Portable Generator...
My 10 years colman generator running ... I feed 240V to the main of the house, it used to work OK. But this time, most of my light bulb went bursted after 3-5 min. However, some are not... what has...
it sounds alot like it is producing alot more power than 120 volts per leg you should really only have plus or minus 10 percent of that voltage anymore will blow lights check voltage output with meter, if voltage is high may have problem with voltage regulator and it may need be replaced. I assume that not all of the lights in the house are on the same circuit therfore not on the same leg of the generator so is probably only one leg of generated power to high there for only blowing some of the lights
Oct 08, 2009 | Coleman Powermate Powermate 5000W...
Surging 5000w Coleman Generator
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
May 08, 2009 | Coleman Powermate Powermate 5000W...
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 5000 generater-no AC output
have you conected the brushes on the right way? the leads are + and -.
you can run it up and use a 12v battery and connect it to the brushes correct polarity, with the othe LEADS removed and taped can shock you and chect the out put it it around 100 120v chech the AVR or brush polarity.
If yours dont have brushes it will have a capasitor that is prob out of spec.
Jan 10, 2009 | Coleman Powermate Powermate 5000W...
5000w gen. no powe out put
when engine runs but no power is produced ...there are three things you need to check:
1- brushes may be shattered.(open the generating unit cover(from the stator and rotor side) and you'll find it..if it is shattered..then replace it.
2- breaker...to test this disfunction...connect the two wires(the one going to it and the one coming out of it) together and try again...if it generated power..then the breaker is out of order...either replace it...or keep it connected directly (DON'T leave any naked wires)
3- AVR open the generatng unit cove again.you'll find the AVR (screwed to the rotor holder) here is a picture of an AVR:93c8b52.jpg if it is burnt out...replace it..
IF you tried the 3 things i wrote and none of them worked, then you have a problem with the stator or the rotor...but that is very rare to happen...it's probably one of the three///..
Dec 17, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
410 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
