Question about Technics SL-1200MK2 Turntable
After a while the pitch increase and decrease randomly, do i need to change the VR301, VR302 or VR201 ? and where, on the net, can i buy those pot ? i'm a paypal user and my turns ar the 1200 mk2, AC 120v 60Hz 12W serial: DA99 07A172 made in japan thanks!
  • 122 Answers
USUALLY JUST THE PITCH CONROL ITSELF NEEDS CHANGING.THEY ARE NOT ALL THE SAME, SOME MODELS ARE MARKED MK2-A
Posted on Nov 21, 2010
I cannot set the time on a Panasonic NN-GD566M microwave oven
Sounds like the dial control on the timer board is bad, the only way to repair it is to replace the whole time board. Try a place called encompass parts. they are a distributor for Panasonic.
Oct 18, 2017 | Panasonic Microwave Ovens
Tip
Tips on changing orifice size on AC or heatpump
Tips on changing orifice size on air conditioners and heat pumps.
A smaller orifice will create these changes
1 - Takes more refrigerant charge to get the same superheat
2 - Increases capacity
3 - Decreases Energy Efficiency Ratio
4 - Increases Head pressure
5 - Increases sub cooling
6 - Reduces suction pressure
7 - Increases Watts and Amps
A Larger orifice will create these changes
1 - Takes less refrigerant charge to get the same superheat
2 - Decreases Capacity
3 - Increases Energy Efficiency Ratio
4 - Decreases head pressure
5 - Decrease Sub cooling
6 - Increases suction pressure
7 - Reduces Watts and Amps
on Jan 26, 2010 | Heating & Cooling
Thorn amplifier model 4044 volume control VR201 faulty.
put a few drops of "switch cleaning oil" inside the volume control by opening the cover & rotate the control a few times. you can use it on switches as well. you will see the control is working again. if that does not work, u need to replace the control pot.
Sep 26, 2011 | Audio Players & Recorders
Constant high pitched whining noise. Increases
you could be low on transmission fluid check that and make sure it registering properly on the dipstick.
Oct 20, 2009 | 2003 Toyota Sienna
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Jul 20, 2009 | Technics SL-1200MK5 Turntable
Getting a high pitched whining sound that increases and decreases with accelleration and decelleration
it is your idler pulley. get it from dealer comes with bracket, just use pulley off bracket. take your belt off and your idler pulley is lower right hand side(facing your engine). 15mm bolt, replace pulley and reinstall your belt. it;s a common problem on trailblazers
May 05, 2009 | Chevrolet TrailBlazer EXT Cars & Trucks
Braking not working right
Well, does the platter spin at a constant speed (33 or 45 rpm), or does it spin super fast? If it spins at a constant speed, and it just wont stop, replacing that pot should do the trick (VR201 can be purchased HERE). You can attempt to replace it yourself (soldering skills are required), or just buy the part, and have a service tech replace it for you.
If it does not solve the problem, then the issue is with one of the IC's (integrated circuits). This is a more complex diagnosis and repair. But try replacing VR201 first, then taking it from there.
- TERMiNAL OPTiC
www.DJPROLAB.com
Mar 03, 2008 | Technics SL-1200 Turntable
Alinco dj-v5 HT deviation adjust
To adjust the deviation of this radio, you don't have to take it apart. If you take the battery pack off, there is a sticker on the back of the radio saying Alinco. Pull that sticker off and underneath are the variable resistors. See the service manual for more details on how to make other adjustments.
First, make sure you note the present position of this pot so you can turn it back if you have to.
If you don't have any equipment to measure deviation, make a contact on the repeater and try turning the pot in small increments and ask the person to help you set the deviation so your voice sounds good through the repeater.
Once set, if the repeater has a touch tone test, go through and make sure all your tones are being properly decoded.
Please let me know if I can be of further assistance to you.
- Jim
KA3EBX
South Hills ARC
www.sharc.net
Feb 26, 2008 | Radio Communications
Technics problems
There is no drive belt on this unit. This is a direct drive turntable. Your pitch control might be on it's way out. Are you getting any sort of unusual speed issues? Or is it just sort of running slower than usual? There is a pot you can adjust under the turntable platter to speed it up a bit, however, this is only a temporary fix. It is listed as VR301 - and is on the main board under the turntable platter - it says PITCH on it. Try adjusting that pot, to see if it does anything. WORD OF CAUTION: Make sure your turntable platter is ALWAYS on whenever you power up your turntable, and if you do any electrical modifications, make sure you always disconnect your turntable from it's power source to be on the safe side. If this does not work, then either your pitch control (which is a variable resistor) will need to be replaced. The problem could also be one of the drive components on the main board, however, this will need to be worked on by a service tech. Hope this helps. - Justin
Jun 11, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
280 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
