Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony 36 in.tv
The picture flashes on and off,sometimes stays on for a few minutes.can not set time on it because it won't stay on long enough to program it.
  • 4,234 Answers
This is usually an indication that the picture tube is starting to fail. A short term "cure" is to increase the screen voltage a bit. This is done by opening up the back and turning the screen control on the flyback transformer clockwise slightly. The flyback if the large part with the red wire coming out of the top that goes to the side of the picture tube. Please note that you only have to turn this control slightly. Ity should be the top control on the two on the flyback. The other is for focus. Also note that there is extremely high voltage there (15,000V) that can be dangerous. If turning up this control resolves the problem, you have bought yourself time to find a replacement only.
Dan
Posted on Jun 02, 2008
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
60 grand wega 5 years old picture getting darker
souns like an over heating isue
try cleaning out the unit
take it to the local mechanic have him give your tv a ******* (with compressed air )
heck hes been screwing you so his kids can go to coledge for years whynot get a freebe?
Aug 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Trinitron: Frozen Static Issue
you could be experiencing two problems. the first part of your description states the static with two horizontal bars, this problem is usually erratic and it is caused by a defective varactor tuner(this happens while watching a channel thru your channel selector) the second part that it also happens while using the front hookups could be taht the front input connectors have developed some loose solder connections and thus the video problems (very common problem)
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony 36 in.tv fdtrinitronwega xbr
This is a duplicate posting. I responded in the initial one. Please see that response.
Dan
Jun 02, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
