TASCAM M-1016 M-1024 Mixer SERVICE MANUAL - Audio Players & Recorders
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
I have a mixer tascam tm-d4000 and stopped working now screen shows "fatal error" can you tell me how to fix it please
Do you have the service manual and the necessary tools and experience? If not take it to a service shop it will be more cost effective.
Jan 28, 2015 | Tascam Audio Players & Recorders
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Tascam manuals M-106 6Channel Audio Mixer
If you only want a manual, Teac/Tascam in Montebello, CA. If you need help with it, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
Dec 17, 2013 | Audio Players & Recorders
What is the user manual for this mixer.
Thank you for your question.
Here is the user manual:
http://tascam.com/content/downloads/products/349/2488MK2_web.pdf
If this helps you, please give me a positive rating.
Thanks.
Rob
Feb 26, 2011 | Tascam 2488 Portastudio Multitrack...
How do I hook up my tascam fw1082 to a mixing board?
Hi, There are two ways you can connect it up. You have a TRS (Tip Ring Sleeve) monitor output that could be patched into the inputs of any analog mixer, balanced high level inputs.
You also have a S/PDIF stereo out. If a digital mixer doesn't accept S/PDIF you can get a converter to change S/PDIF to an AES, which any pro digital mixer will work with. I think HOSA has one for about $60.00, you might find something on Ebay as well.
Here is a Link to the TASCAM Spec page for you FW-1082
http://tascam.com/product/fw-1082/specifications/
I hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Tascam Audio Players & Recorders
I HAVE A TASCAM DIGITAL MIXER TYPE DM-4800. I NEED IT TO CONTROL MY TASCAM HARD DISC RECORDER TYPE X-48. I NEED CABLE CONNECTION AND SETUP INFORMATION
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Jul 18, 2008 | Tascam Audio Players & Recorders
1,347 people viewed this question
 Grubhead
Grubhead
