Question about Avermedia UltraTV PCI 300 Video Capture
Jane game piece was on 139. she usedthese cards to capture a marker: using a 300 chart
After installing the game the USAF is not working.
hello top gamer!
Sometimes , specs, are very high! usually OS, or Video Cards, but it is "suppose" to work I know!
For sure, try updating the video driver, and compatibility modes, instead use windows 7 compatibility mode. see if work!
Carl
Mar 28, 2016 | EA - Electronic Arts Jane's Air...
Why would only one out of 4 marker lights work?
you are right all marker lights come off of one fuse, inside instrument panel, number 29, a 10 amp fuse my manual does not give a lamp number, it has a chart, head lamps (high) lamp 9005 60 w type a, headlamp (low) 9006 51 w type b, front marker lamps 5w type d, for the rear it says to use a lamp 7443 21.5 w type d, I do not use these, I have special lights on mine, hope that it helps
Mar 28, 2015 | 2007 Scion tC
Easier instructions for Rook card game
Four players are organized into two teams of two players each, sitting opposite each other. Players must keep their hands secret from all other players, including their teammates. The object of the game is to be the first team to reach 300 points by capturing cards with a point value in tricks. If both teams have over 300 points at the end of a round, the team with the higher point total wins.
Only certain cards have a point value. These are known as counters. Each 5 is worth 5 points, each 10 and 14 is worth 10 points, and the Rook Bird card is worth 20 points.
The Deal The 1s, the 2s, the 3s, and the 4s should be removed from the deck, and the Rook Bird card should be added, for a total of 41 cards. The dealer shuffles and cuts the deck, then deals all of the cards, one at a time. After every player has received his or her first card, the dealer places one card in the center of the table. This is repeated until there are five cards (the nest) in the middle of the table. The remaining cards are dealt normally.
Bidding After the deal, players bid in increments of 5 points for the privilege of naming the trump suit. Bidding starts with the player to the left of the dealer and passes clockwise. The minimum bid is 70 points, and the maximum is 120 points (the number of points a team would make if they captured all the counters in the game). If a player chooses not to increase the bid, he may pass to the next player. A player that has passed may not make another bid for the round. The high bidder adds the five cards of the nest to his or her hand, then lays any five cards to the side. The high bidder then names the trump suit.
Play After the trump suit has been named, the player to the left of the dealer places any card of any suit face-up on the center of the table. Play proceeds clockwise, with each player playing one card face-up in turn. After each player has played, the player that played the highest card of the suit of the leading card takes all of the cards played, or "takes the trick".
A player must either follow suit (play a card of the leading suit) or play the Rook Bird card. If a player has no cards of the leading suit, he or she may play any other card, including the Rook Bird card or a card of the trump suit. The highest card of the leading suit takes the trick, unless a trump card is played, in which case the highest trump card takes the trick.
If a player reneges, or fails to follow suit when he or she could have, the error may be corrected before the next trick is taken. If it is not discovered until later, the round ends, and the team that made the error loses a number of points equal to the bid, regardless of which team made the bid. The opponents score all the counters they captured before the error was discovered.
The person who takes the trick leads in the next trick. When a trick is taken, it is placed face-down in front of the player who took it. Tricks taken may not be reviewed by any player until the end of the round. The player that takes the last trick in a round captures the nest and scores any counters in it.
The Rook Bird card The Rook Bird card is the highest trump card in the game. It takes any trick in which it is played.
You may play the Rook Bird card at any time, even if you are able to follow suit. It is the only card that may be played this way. If the Rook Bird card is led, all other players must play a trump card, if they have one. If the trump suit is led, and you have no other trump card, you must play the Rook Bird card.
Scoring When all possible tricks have been taken, each team adds the counters it captured. If the bidding team failed to make the number of points bid, the team loses a number of points equal to the amount of the bid, and does not make any points for counters captured in the round. The opposing team receives points for any counters they captured.
The first team to reach 300 points is the winner.
Aug 02, 2014 | Hasbro Rook Family Young Adult and Kids...
Capturing XBOX 360 Gameplay
If you both have Xbox 360s and want to play together, just buy an Xbox Live subscription and play via the Internet. Otherwise, it is impossible to play with him via Skype because your controller would not have an adequate range to connect to his console.
Jun 22, 2013 | Microsoft Xbox 360 Console
I got a Janes ATF from 1996 I think..it starts to install but before its finished it indicates "exit to dos"...I have Windows XP..is it not compatible?
No. I would not install. XP was the 1st Windows OS to truly leave DOS behind. You'e only asking for problems.
I'm using XP, and I got rid of all those old games.
Sep 28, 2012 | Electronic Arts Janes Combat Simulations...
Charting a route on water
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Jul 18, 2012 | Lowrance Hds 5 Hds5 Fishfinder gps Chart...
Instructions as to HOW TO PLAY DRAUGHTS
  • Set up your pieces on a black-and-white checkered game board with 64 squares of each color. Each player should set their 12 pieces on the 12 black squares closest to them on opposite sides of the game board.Decide who goes first by tossing a coin.Move a game piece forward diagonally along the black squares if you are the first player. You may move only one square at a time per turn and you must go forward on the board.
  • Take your opponent's game piece by jumping over it forward diagonally along the black squares if your opponent has one of his game pieces adjacent to yours and there is a vacant space beyond your opponent's piece. You may take more than one jump if you land on a space where you are able to jump another of your opponent's game pieces
  • Have a game piece crowned as a "king" if you reach the far edge of the board closest to your opponent. Your opponent must place one of the game pieces he has captured from you on top of your king piece to distinguish it from your other pieces. Your king is now allowed to move diagonally forward or backward instead of just forward.Win the game by capturing all of your opponent's game pieces,Hope this helps :D
  • Jul 16, 2011 | Toys
    Thanks for this thread, I am so frustrated. I ;have a windows pc with XP sp2. I use Windows Movie Maker, mostly. I have a pinnacle av/dv card, which has a firewire input, as well as the rca jacks. Feeding...
    i love a well informed person with computers. so many people post here and don' t give any other information; and for that i thank and congratulate you. now for your resolution. i have read up on this particular unit and with this one i have found several hundred issues with the quality. especially when viewing on larger LCD screens.
    knowing this, i suggest the upgraded model. Canopus ADVC 300 Analog / Digital Video Converter......http://www.firewire-1394.com/canopus-advc-300.htm
    now with that said you mentioned you have a pinnacle av/dv card. my question involves the issue with your firewire. on most cards of this nature they want to be "alone". meaning that the card wants to be in a pci slot to itself with no neighbors. i suggest putting it in the very first slot available to avoid this and then putting your other cards in the remaining slots. this card you are using is also a little outdated. here is a better card.... http://cgi.ebay.com/Compro-Videomate-C500-PCI-DV-Analog-Capture-Card-2-/170586107840?pt=AU_Components&hash=item27b7b96fc0#ht_1080wt_905
    If you have any problems let me know and please leave positive feedback for me. Jethro
    Feb 01, 2011 | Canopus ADVC-110 A/D Converter...
    I cannot bring up a marine chart showing depth and markers on my
    Marine maps must be installed on SD cards. The base-map does not contain marine maps. Most on-line or brick-and-mortar hunting/fishing stores carry map cards for Lowrance units.
    May 28, 2009 | Lowrance iFinder Expedition C Handheld GPS...
    Playback/capture
    Awesome. I might have to do that real soon myself.
    Jul 02, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
    Avermedia UltraTV PCI 300 Video Capture Logo
    250 people viewed this question
    Top Avermedia Televison & Video Experts
    Vernon Taylor
    Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
