Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Maytag Quiet Servies 100
My problem is that quite often the dishes are not rinsed well. We do an excellent job of rinsing the dishes before we even load the dishwasher. Also, it is not a problem of how we load, we are good at that too. The machine seems to need some sort of filter cleaning or water pressure adjustment. We have a water softener.
Bill
  • 868 Answers
Make sure your getting at least 120 degrees in water.Check the heater element,rinse aid ,clogged up spray arms.These are the most common and need to be 100% ok.
Posted on Jun 02, 2008
Not draining. fills, then smells Maytag quiet series, 100
there is clog in your main drainage line, you are smelling the decay of your food, rinse off your dishes before placing them in the dishwasher
Jul 22, 2010 | Maytag MDB5100A Dishwasher
Grit on clean dishes.
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 18, 2010 | Maytag 24 in. MDBH940AWS Built-in...
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second problem...it has become very loud and sounds like it is chewing up all the dishes.
PattyQ
Jan 10, 2010 | Maytag Dishwashers
Doesn't get dishes clean soap doesn't even rinse off
use less soap and you have to pre wash your dishes it is a washer not a food grinder
Dec 06, 2009 | Dishwashers
My maytag dishwasher doesn't seem to be rinsing
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 25, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Our Maytag quiet series 200 does not clean or rinse dishes properly. It leaves film all over cups and dishes. Water also seems not to be draining out. It is 6 years old
It is not the dishwasher. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 07, 2009 | Maytag Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Grinding noise for maytag quietseries 200 usually when it first starts up
I had the same problem with my Maytag Quiet Series 1 dishwasher until I read the comment left by the guest on June 1, 2008. I tried his suggestion about the rinse cap adjustment and WOW it WORKED. No more growling noise. Thanks you saved me a service call.
Apr 06, 2008 | Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
81 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
