Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Menu screen keeps appearing. Remotes no longer control the TV
Remote doesn't work. Menu screen appears when channel, volume, or input button is pressed (buttons on the set).
Realized by avoiding scams like this website who want to cash in on frustrated electronics owners, and instead just talk to the manufacturer of my TV. Sony walked me through the problem and corrected it.
Nice try, almost had another one
Posted on Jun 02, 2008
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; also has a replacement remote available that has been programmed for the TV. (On, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
Is there any way to get into menu to change from "ant" to "cable" without remote? TV does not have original remote and universal remotes will not access menu options.
Hold volume -/+ few seconds, menu will appear. Navigate up/down menu with channel buttons, page change with volume buttons.
Jan 21, 2014 | Sansui DTV3200 32" TV
Cant load channel sound but no picture
First reset it to factory default: While pressing [VOLUME ( - )] button on the TV, press [MENU] button of the remote control 2 seconds, the self check screen will appear, then Unplug Power to reset.
If doesn’t work, update the software, if still not work, let me know.
May 31, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Sylvania 27" derailed by Emerson universal remote
Aug 25, 2008 | Orion STV2763 27" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from:
Mar 16, 2008 | Toshiba 24AF45 24" TV
"ch set" appearing on screen
Need to get into the menu pages to setup the tuner. Just buy a under $10 universal remote but make sure it has a menu button.
Or - many other products that use remotes often have an option for programing it to work with other equipment.
Dec 30, 2007 | Emerson TS1997 19" TV
Game Mode
On the TV itself, press the MENU button. When the menu opens, "PICTURE" should be highlighted in pink and the rest of the menu items will be an aqua color. That means you are in the right place....Press the volume "up" button... this will open up the Picture menu items. When the menu opens, start pressing the channel "up" button. You will see (bright, color, etc.) options in this menu. Keep pressing the channel up button until you see "Game Mode"... the options will be ON and OFF. Use the volume "up" and/or "down" buttons to toggle back and forth between ON and OFF... if you want to watch TV, be sure to turn the Game Mode OFF... otherwise the picture will be VERY dark...
Dec 24, 2007 | Symphonic ST419E TV
Remote control no longer works
an original remotes available for ya at for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
