Question about Watches
How to remove links from a chanel ceramic watch?
slp11508
  • 43 Answers
SOURCE: Link pins keep falling out on Ceramic Watch
They probably forgot to put the little locking barrel back in before hammering the links shut again. Some watches have the link, the pin, and a barrel that goes in the link before the pin is hammered in. If your watch needs this barrel then the pin will NOT stay in without it, no matter what.
Posted on Jan 05, 2009
disap1
  • 98 Answers
SOURCE: i have a michael kors white ceramic watch and the
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Posted on Jan 16, 2010
escapement
  • 2334 Answers
SOURCE: remove links on a ceramic Oniss Watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to remove or add links.. Rate me, please .
Posted on Apr 14, 2010
gemineye61
  • 831 Answers
SOURCE: I am searching for a
Thanks for contacting FixYa. Unfortunatley I had no luck finding a manual but you could try to contact them at this link:
http://www.chanel.com/apps/contact/html/ecrivez_nous.php?zone_lang=USAEN
Best regards. Jewel
Posted on Sep 13, 2010
SOURCE: how do i adjust a chanel watch strap. ceramic
Cut the sharp end off a small pin and insert it in tiny hole on pivot pin. Tap it lightly with strap supported on a solid object with a small hole in it and the two piece pin will come adrift. Then you may remove or add a link and tap the two part pins together again.
Posted on Oct 06, 2010
What size battery for a 29mm white ceramic chanel watch use
What model number is on the back? 29mm is usually related to the width and nothing else
Jul 08, 2013 | Watches
Replace links on Swiss legend ceramic watch
here is a video that will show you how to remove links on your ceramic watch band
Jan 18, 2013 | Swiss Legend Karamica Chronograph Ceramic...
How do you remove creamic links from a Chanel J12?
You have to have a tool small enough to push out the links, usually there are arrows showing which way to push the pin the arrows will be on the band. take a small hammer and gently tap on the tool to push the pin out. The ceramic is very strong so the hammer is safe, i have shortened many of these.
Aug 27, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
I have a le chateau ceramic sapphire watch and want to remove a link
mcdevito75 here, You"ll need a link remover tool, available on ebay, but my advise is if you know nothing about watches, visit a small watch repair shop in your area and have them remove the link, also, hold onto that link in case you need it replaced later.
Aug 17, 2010 | Watches
How to reduce size on a Rado Diastar wrist watch
That links are most likely ceramic! Take your watch to a reputable watch repair shop...they break very EASY! Make sure they know what they are doing!!!!
Jan 15, 2010 | Rado Diastar Anatom Jubile watch
I have a michael kors white ceramic watch and the band is too long? how do i remove links?
Jan 15, 2010 | Watches
How do i adjust a chanel watch strap. ceramic
Nov 22, 2009 | Watches
Dec 29, 2008 | Swiss Legend SL-LUCERNE-ML134AC Wristwatch
Watches Logo
500 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
