posted by Rlforward on Jun 02, 2008
I recently blew my PSU and replaced it with an identical unit. However everything was dead after intalling the new PSU. I was informed the PSU also took out my Asus motherboard when it blew. I relplaced my motherboard with a Asrock P4i65G but everything is still dead. Could the problem now be the CPU or DDR memory? I am using the P4 3Ghz 1m Socket 478 CPU 800 FSB SL7PM and Elixir 512Mb DDR-400MHz-Cl3, PC3200U-30330 memory. Is this compatible with the new motherboard and could that have also blown when the PSU packed in?
Best Solution
posted on Jun 02, 2008
If the CPU is dead the problems can be
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
- no power
- no fans etc or
- power, no beeps (errors)
Comment by mewms_14904, posted on Jun 02, 2008
The processor is a prescott and is supported by your board.
The ram is also supported.
Rating Locked! (?) Rlforward has rated this solution as FixYa!
This Problem Also Relates To:
HP Compaq Motherboard
HP (KZM-6120) Motherboard
HP (P2074-69003) Motherboard
AOpen AK77-8X Max (91.8A710.101) Motherboard
ASUS P5PE-VM Motherboard
ASUS 865G (MBAS-P4P800VM) Motherboard
ASUS P5RD1-VM Motherboard
Can you Help with these Motherboards problems?
Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
bios resets to 07-31-2007 when...
bios resets its self when i... Answer This...
Repair Service
Find Motherboard Repairman Near You:
