Question about Apple iPod nano
My volume got locked on my ipod. how do i unlock it?
  • 864 Answers
Unfortunately the password is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs.
Click "Get Info"
Click "Yes"
Click the "Options" tab
Check "Volume Adjustment"
Put the Curser all the way to "+100%". Select Ok!
Hidden Folder for Mac's
Enable hidden folders.
If you go into Terminal and run these two commands all the hidden files appear when you open Finder.
defaults write com.apple.finder AppleShowAllFiles TRUE
killall Finder
To get back to hiding hidden files use these commands
defaults write com.apple.finder AppleShowAllFiles FALSE
killall Finder
Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC
In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod.
Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to musictoo loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working. -Midwest-tek
Posted on Oct 22, 2010
Volume limit lock how do i override the it ?
If you know the lock code, you should be able to unlock the volume limit by following the menus under Settings. If you don't, then some technical work is needed. Instructions are here: http://www.wikihow.com/Unlock-iPod-Volume-Limit
Aug 15, 2009 | Apple iPod nano
Ipod nano volume locked forgot password
Basically you cant unlock the voulume if you dont know the password. You would probably have to reset your iPod in order to adjust your volume and when you put a new password in be sure to remember it.
Feb 25, 2009 | Apple iPod nano 3rd Generation
Ipod Nano can't unlock volume lock
I assume your music is stored safely in iTunes on your computer? If so, just do a Restore on the iPod through iTunes to reset your iPod to the factory defaults. You will have to copy your music back, but the lock will be removed.
If your music is not saved on a computer, use software such as ephPod to get the music off - then do a Restore. (see: http://www.engadget.com/2004/11/02/how-to-get-music-off-your-ipod/)
Good luck.
Jan 03, 2009 | Apple iPod nano
To unlock the volume
When connect ipod to computer, go to my computer. Click on ipod:-
-click on tools, go to folder options
-go to view tab
-check: show hidden files
-a ghost like folder will apear: ipod control
-click on it and go to device
-there will be a volmelocked file
-click and delete it
Your ipod volume is unlocked!!!!!!!!!!!!
JOHN
If you don't understand, go to this website on you tube! It's mostly the same, it will get you to the folder but make sure you delete the right file!
http://www.youtube.com/watch?v=Au6H_u-q434
Nov 19, 2008 | Apple iPod nano
on my ipod the volume limit is a software setting in the menu that does not require any kind of passcode so you have me a bit confused as to what you are asking
Oct 13, 2008 | Apple iPod nano 3rd Generation
Sounds like you need a New ON/Off switch which is connected to the headPhone Jack. We can definetly do this for you. Please give us a call to set up a Repair at 661-619-5928 or Email us at sales@ipodrepairz.com
We look foward to your Business and also repairing your iPOD
Thanks Again
ipodrepairz
Also check us out on Ebay.com under ipodrepairz
Sep 19, 2008 | Apple iPod nano 2nd Generation MP3 Player
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Aug 03, 2008 | Apple iPod nano
From my experience with iPods, the only way to get rid of lock codes that you can't remember is to do a restore on your iPod. This will result in all data being removed from it however. But if you have a backup on your computer of everything you have, then you should be fine. You will have to reload all your music and stuff.
Jul 11, 2008 | Apple iPod MA446LL/A MP3 Player
Heres how
http://www.fixya.com/support/r538899-unlock_ipod_volume_control
Remember to rate my solution as fixya, becouse I know this will fix your problem as it has for many others before you!
May 16, 2008 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
