Question about EliteGroup A907 Notebook
How to disassemble ECS A907 laptop? guide please help.
Xp very slow with ecs a907
- Make sure you have enough empty space on discs
- Open task manager and close any unneccesary processes running in background
Delete all unnecesary applications
- Upgrade hardware (RAM, CPU, graphics card, etc.)
- Uninstall unnecessary programs (Games, crapware, toolbars, etc.)
- Click start>Run.. Type msconfig>enter>Start Up. Uncheck the boxes for the programs that you think you may not use often
- If this didn't help you then simple get the Intel software partner Reginout to fix all registry issues which causing your window slow
Jun 12, 2013 | EliteGroup Computers & Internet
I want to locate and replace the CMOS battery in an ECS 600L laptop
The job would require a lot of dis-assembly, and I feel compelled to tell you that unless you are very tech savvy, that is not a task to be done with ease. However, here is the dis-assembly guide you should follow, should you decide to do this.
Disassembly Guide
Dec 09, 2012 | EliteGroup 600L Notebook
Where can I get a guide to replace LCD panel on a toshiba satellite a505-s6973?
Hi klkdaddy1
TOSHIBA SATELLITE A505-S6970 NOTEBOOK LCD PANEL DISASSEMBLY GUIDE
The general LCD Panel Disassembly Guide for Toshiba notebooks like your can be found here:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/replace-LCD-screen-1.htm
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 07, 2011 | Toshiba Satellite A505-S6970 Notebook
Sche matics for a toshiba satellite A205iskaa la-3481p motherboard so i can reset the bios password or remove it.
Hi schollmd
DISASSEMBLY GUIDE FOR TOSHIBA SATELLITE A205 LAPTOP
On certain laptops, it is possible to delete the BIOS Memory by temporarily disconnecting the CMOS/RTC Battery before reconnecting it and reassembling the laptop.
Sometimes this requires almost total disassembly of the laptop.
So no damage is done during disassembly and the correct component positions and cable connections are restored during reassembly, this is a job best done by an experienced repair technician.
While yellow is a common colour, the CMOS/RTC Battery can also be encased in blue, brown, black or green plastic.
On some models the CMOS/RTC Battery is accessible without disassembly, via the Wireless Card compartment underneath the laptop.
On other models, disconnecting and reconnecting the CMOS/RTC Battery is ineffective in clearing the BIOS Memory Cache because nearby capacitors store the data if the Battery is removed. Two contact points on the motherboard have to be bridged in order to dissipate the charge from the capacitors to reset the BIOS.
The Step-by-Step Disassembly Guide for this model series of laptops can be viewed here:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-4.htm
I hope this helps.
Oct 01, 2011 | Computers & Internet
No power at all.. totally dead.. pls Help..
If you plug the charger cord attached to the charging light starts to blink or burn?
Mar 14, 2011 | EliteGroup A907 Notebook
I need to install audie devies for aspire a907
I'd need to know the model # located off the rear or bottom of the unit to get the correct driver for it. Or do it yourself by going here: http://www.acersupport.com/desktop/index.html
Jun 10, 2009 | Acer Computers & Internet
Remove hard drive from ecs g900 laptop
To access it it is on the bottom and you have to remove the screws
but you should BACK UP FIRST
Aug 28, 2008 | EliteGroup ECS G900 Notebook
ECS Elitegroup Laptop Driver
http://www.ecs.com.tw/ECSWebSite/Downloads/Category_Download.aspx?MenuID=6&LanID=0 ---here is the site of ECS, you can download here your driver. Just Choose from the drop down boxes your Product Category, the Model of your ECS Laptop and Version if any and click on next and your driver will appear. Hope this helps.
Mar 29, 2008 | EliteGroup ECS G900 Notebook
EliteGroup A907 Notebook Logo
131 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
