Question about Sanyo DS24425 24" TV
How do I adjust the screen to the TV - I've looked in the MENU options and can not adjust the height of the screen. In other words - I can not read the score ticker on the bottom of the screen
    Top Expert:
  • Sanyo Master
  • 74,468 Answers
Your sanyo tv may have service mode adjustments. It can be taken according to the sevice code options, which can be get from service journals available in the market. no menu adustment is there to adjust the picure linearity, height , subbrightness control so on. All adjustments are coded and have critical measurements which can be adjusted through service mode with the help of remote control. The remote control should be orginal to access service mode. Duplicate may not work properly.
Posted on Oct 14, 2010
Make computer display fit tv screen mitsubishi wd 65738
If you are only going to use the set with the laptop here is a link to the service manual with electrical adjustments for height, width and other things---"enter at your own risk.'
http://www.scribd.com/doc/52160908/27/Service-Menu
Dec 15, 2012 | Mitsubishi WD-65738 DLP TV
I've lost restore down in Word. How can I get it back?
if you are referring to microsoft word
Microsoft Word is one of the most widely used text editors in the business world today.
Using Word, you occasionally experience glitches like missing Menu items.
You open Word and while preparing your document realize the Menu item you want to use has magically disappeared.
You can restore it easily.
There are ways to restore lost Menu items in Microsoft Word.
Check your Menu to confirm the button you are looking for is really missing.
Microsoft Word is intuitive and continually adjusts to show the options you choose most often.
Click the double arrow near the bottom of the Menu items to reveal the hidden options.
Click the Menu item you are looking for.
Use that Menu item often and Word will place it in your Menu for easy access.
Replace the missing Menu item in Microsoft Word. Click Tools - Customize.
Select the Commands tab.
Click Rearrange Commands.
Add the Menu item you lost in Microsoft Word.
Select the Menu bar at the top.
Use the drop down menu to select File. Open Controls.
Highlight the Menu item under the File menu and click the Add button.
Select File under Categories. Open Commands and select desired button.
Click Ok.
Word will reveal a preview of the File menu including your changes.
Select the desired Menu item.
Click Add.
To adjust the position of the Menu item you added.
Click Move Up or Move Down.
Continue to adjust them until you achieve your desired results.
Click Close to close the window.
Click File, Exit to close Microsoft Word.
hope this helps
Oct 14, 2012 | ASUS P5PE-VM Motherboard
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
I have a sylvania model 6432 te model my words are blurry and hard to read whats up with that
The vertical height and lenearity confuguration to your tV has been changed. Now vertical height is more than normal. To adjust this, you have to enter the service mode option window. It is an entirely different window, than its Menu windows.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Entering into service mode to many brand of TVs are described here. Pull up older posts there.
Sometimes, advertaisements at the side and bottom of each post might help you.
May 23, 2012 | Sylvania Televison & Video
Mitsubishi VS-50803 Big Screen TV - Trying to hook up an HDTV cable box, I was told to hit: menu, 1, 3, 7, 0 - to get to the service menu and switch DTV over to HD and that would solve my no signal...
First please confirm actual model number on rear of set.
Something is not right here, I am looking at Mitsubishi material downloaded in my computer; shows all codes for sets up to 2004. VS-50803 is a VZ6 Chassis made in 1998 and I doubt it is HD set, if it is one of the early ones it will have beneath the HD input vert sync and Horz sync---those required a special box from Mitsubishi etc.
Set has 3 hidden menus:
1. Option menu (for hard reset)= Menu 1,3,7,0 enter
2. Circuit adjust menu= Menu 2,3,5,7 enter
3. Convergence adjust menu= Menu, 2,3,5,9,enter (#4,5,6 on remote then change modes)
Does the DTV input have the two vert, horz jacks as well?
First is the Option menu is really only for a hard reset of the entire set, if you engaged it you may have de-converged the set.
The adjust menu is for height, width etc
The convergence menu is for convergence.
If you did something and did not save it, unplugging set should put it back to before what you did.
In the OPTION MENU WHAT DID YOU SELECT AND DID YOU HIT ENTER WHEN YOU FINISHED?
STEVE
Oct 08, 2011 | Televison & Video
How do you adjust picture width and height on JVC 32" CRT TV Information bars on Sky Sports News cannot be read
change the aspect ratio on your tv on screen menu, if that doesnt solve it go into settings on the sky box and change it to letterbox
Feb 26, 2011 | Televison & Video
Tv is alittle blurry, its hard to read words
when its hard to read words its usually the sharpness which make the t.v.'s look either blurry or sharp or right in between. you can fix this by adjusting it thru your tv's menu either on the tv or your remote, look under the picture tab in the menu and there should be a sharpness adjuster there. adjust as needed
Oct 13, 2009 | Televison & Video
Certain aspect of my sanyo tv are very blurred
This problem requires adjusting the Focus on the flyback . Turn the tv around and look for adjustmen slots on the back. If you can see them, use a nonmetalic small srewdriver and slighty adjust the top or left one. Be careful, it is the high voltage area
Sep 15, 2009 | Sanyo Televison & Video
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sanyo DS24425 24" TV Logo
353 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
