Question about Siemens S25 Cell Phone
My mpbile phone siemens s25 just lights up it dose not load the operating system.. what shall i do ? thanks
  • 3 Answers
Remove the battery, wait a few seconds and plug the battery back in.
Posted on Oct 14, 2010
Where can I down load an English Operating Manual
here is the link for your download . http://www.google.co.in/url?sa=t&source=web&cd=1&ved=0CBUQFjAA&url=http%3A%2F%2Fgigaset.com%2Fmedias%2Fsys_master%2FA31008-M2003-D201-1-5719_30-10-2008_pt_PRT.pdf&ei=TiEvTOKXEYKzrAePmN3zBQ&usg=AFQjCNGoyKWzB-FEdleT7Xx_VkXuA5L2MA
Jul 03, 2010 | Siemens Gigaset 4000 Phone
Samsung jet S8000
you have lost your operating system or shall i say your firmware failed to load. go to your nearest samsung service center and they can load or flash the right firmware there to your phone.
don't try to flash it by yourself if you don't know what to do, or else, you may end up bricking it...
Feb 19, 2010 | Samsung Jet S8000 Cell Phone
Manual for Thermostat Siemens RDJ10RF
THE BOILER READS ROOM STAT OFF, BUT IN ACTUAL FACT IT IS ON, PLS ADVISE WHAT TO DO
Nov 08, 2009 | AT&T Siemens S46 GSM Cellular Phone
I am looking for a user guide for model 7010 Siemens Eircom,my phone no.is0214291987
Thank you for your reply, a daughter of mine solved my problem for me. So,I shall not be needing the User Guide after all.
Aug 31, 2009 | Siemens Lands Phones
Nokia siemens ADSL Modem c2110 USB Driver
if u want Nokia siemens ADSL Modem c2110 USB Driver then reply me at binay00713@gmail.com the driver is working great in windows 7.
Nov 01, 2008 | Computers & Internet
Code locking of siemens mobile phone
Siemens Mobile Secret Codes:
C25:
SP unlock *#0003*(secret code 8 digits)#
*#0606# shows you Secret Code, but only without SIM Card.
*#06# for checking the IMEI (International Mobile Equipment Identity)
How to change PIN:
**04*old PIN*new PIN*new PIN#
How to check simlock status
*#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
S4:
Monitor Mode - how to activate:
Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
How to see date of software:
Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) >abck to "normal" and then left soft-key, 56.
S6, S8:
If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
S10, E10:
In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
S15e:
Monitor Mode:
Code: *#7436267*8378# (*#SIEMENS*TEST#)
Hold red phone button until it code disapears.
Menu 3.3.4 Choose frequency.
Menu 3.3.4.1 Automaticaly.
Menu 3.3.4.2 Choose GSM-900
Menu 3.3.4.3 Choose GSM-1800
Menu 10.1 MS info
Menu 10.2 Soft date
Menu 10.2.1 Software version.
Menu 10.2.2 EEProm version.
Menu 10.3 Tst and product info.
Menu 10.3.1 Handware data.
Menu 10.3.2 Date of manufacture
Menu 10.3.3 Service date
Menu 10.3.4 Date of repair.
S25:
Enhanced Full Rate
*#3370# turns on
#3370# turns off
Haft Rate Mode
*#4720# turns on
#4720# turns off.
Languages:
*#0000#+green phone - choose automaticaly
*#0001#+green phone - English
*#0030#+green phone - Greek
*#0031#+green phone - Netherlands
*#0032#+green phone - French
*#0034#+green phone - Spanish
*#0039#+green phone - Italian
*#0049#+green phone - German
*#0090#+green phone - Turkish
How to change PIN2?
**04*old PIN2*new PIN2*new PIN2#
What is my software version?
Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
How to extend battery life:
IrDA - turn on only when you need.
Turn off automatic network search (6-3)Turn off Vibration alarm.
Resets language to automatic selection : * # 0000 # then Green button
S25, M35, S35, C35
Nov 29, 2007 | Nokia 1100
Siemens 825 Gigaset
I have the same problem with mine - a Siemens 2420 base. The calls come in, all the lights flash, then the thing clicks and resets. At this point, it can only be used for outgoing calls. i think i'm going to retire it. Too bad, cause the speakerphone was one of the best ever.
Nov 28, 2007 | Siemens Gigaset 8825 Cordless Phone
Manual for siemens HHB-610 Bluetooth
SIEMENS HEAD SET MANUAL TO PAIR YOUR SEMENS HEAD SET TO A NEW PHONE YOU HAVE TO PUT IT IN TO BLUETOOTH SCAN MODE THIS ALOWS YOU TO FIND THE HEAD SET WHENYOU SCAN FOR NEW DEVICES. TO ENTER BLUETOOTH SCAN MODE PRESS (MUTE AND VOL+) AT THE SAME TIME FOR 5-10 SECONDS , THE LED SHOULD NOW BE A SEADY GREEN LIGHT. SCAN FOR BLUETOOTH DEVICES ON YOUR MOBILE YOU WILL FIND HHB 610 SELECT TO PAIR THEN ENTER 0000 AS PASSWORD .YOU ARE NOW READY TO USE. SYSTEM RESET PRESS (MUTE AND PHONE) AT SAME TIME FOR 5-10 SECONDS THE LED WILL FLASH RED/GREEN FOR ABOUT 5 SECONDS SYSTEM HAS NOW RESET.
Feb 12, 2007 | Siemens HHB-610 Wireless Headset
Siemens S25 Cell Phone Logo
235 people viewed this question
Top Siemens Cell Phones Experts
michael galang
Colin Stickland
Colin Stickland
William Alequin
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
