Question about Dynex 32 in. LCD Flat-Panel HDTV
Some of my video setting are not highlighted how can I acess these settings?
    President:
  • 1,140 Answers
If you are in analogue mode, switch to digital mode - usually marked as DTV on the remote. Alternatively, if you are already in digital, switch to analogue mode - again press DTV on the remote.
Some menu/setup/picture options are only available in analogue and others only available in digital. Don't ask why . . . it's stupid.
Please rate my solution if this helps. Thanks.
Posted on Oct 14, 2010
How do i configure mms on nokia C3-01?
1. Press the Menu button 2. Highlight 'Messages', then press Select 3. Highlight 'Message settings', then press Select 4. Highlight 'Multimedia msgs.', then press Select 5. Check that 'Save sent messages' is set at 'No'. 6. Check that 'Delivery reports' is set at 'No'. 7. Check that 'Allow multimedia reception' is set at 'In home network'. 8. Check that 'Incoming multi-media messages' is set at 'Retrieve'. 9. Highlight 'Connection settings', then press Select 10. Highlight 'Active multimedia settings', then press Select 11. Highlight the next available Set (e.g. Set 1), then press Activate 12. Highlight 'Edit active multi-media settings', then press Select 13. Highlight 'Settings' name' and press Select (left softkey). Enter 'giffgaff MMS', then press OK 14. Highlight 'Homepage', then press Select (left softkey). Enter 'http://mmsc.mediamessaging.co.uk:8002' and press OK 15. Highlight 'Session mode', then press Select (left softkey). Highlight 'Permanent' and press Select 16. Highlight 'Data Bearer', then press Select (left softkey). Highlight 'GPRS' and press Select 17. Highlight 'GPRS access Point', then press Select (left softkey). Enter 'giffgaff.com' and press OK 18. Highlight 'IP Address', then press Select (left softkey). Enter '193.113.200.195' and press OK 20. Highlight 'Authentication type', then press Select (left softkey). Highlight 'Normal' and press Select 21. Highlight 'User name', then press Select (left softkey). Enter 'giffgaff' and press OK 22. Highlight 'Password', then press Select (left softkey). Enter 'password' and press OK 23. When asked to 'Verify new password' enter 'password' and then press OK 24. Press Back (right softkey) 6 times to return to the standby screen.
Aug 16, 2014 | Nokia C3 Touch and Type Cell Phone
I have a Kodak M850 Easy Share hooked up to my television with an mini HDMI cable. The picture shows nicely but I don't know what camera button to use to make a slide show appear on the tv. Can you help?
Starting the slide show
  1. Press the Review button, then press the Menu button.
  2. Move autourg00422004id1197998.jpg to highlight Slide Show [img src="http://resources.kodak.com/support/jpg/en/manuals/GLB_en_urg_00422_images/autourg00422004ID1198002.jpg" alt="">, then press the OK button.
  3. Move autourg00422004id1198023.jpg to highlight your option, then press the OK button.
Mar 18, 2014 | Kodak Cameras
Paket data acess point not valid
Hello Reset the phone by selecting "Restore Setting Only" from the phone setting and request new configuration from this link How to: GPRS.Good luck.Thanks for visiting fixya
Sep 10, 2012 | Nokia X3 Cell Phone
I cant acess my actiontec gt724wgr gateway login and the ip adess 192.168.0.1 is here any other way i can log in?
No there isn`t. Try to reset the router with the little hidden 'Reset' button on the back(just push it once and hold it that way until the indicator lights change) and try again. If it`s still not working, you`ll have to change your computers IP address to 192.168.0.X (X = 2-255).Control Panel > Network and Sharing > Change adapter settings(on the upper left side), right click on the adapter and select properties. Highlight the Internet Protocol version 4 and click Properties. After your done setting it up change the settings back to 'Automatic'.
Good luck
Mar 18, 2011 | Actiontec Electronics (GT724WGR) Retail...
I am not abel to acess face book from my laptop. i tried everything still i am not abel to acess. pls tell me how to acess my face book. i am not abel to acess face book at all.
Use a different browser as facebook require cookies and If cookies are deleted then site doesnt load.Use opera browser. Check the security options of internet and set it to normal, check firewall setting of either anti virus or windows it may also cause the problem.
Mar 12, 2011 | Facebook Social Network
Wep code
This code is from your router and not the motherboard. Go to the website of your router manufacturer, and get the install program from thier site, or at least the directions.
The security code(WEP)is a wireless acess code.
Here are the highlights of what should be set:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Feb 04, 2011 | Computers & Internet
Wpa key what is it as when i put it in i get error 8013013d
Acess the router settings page of your router then set the settings to WPA then look for the network key. You can also personalize the network key on the router settings page. So that you can easily remember it.
Thanks for using Fixya
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Using of internet SETTINGS
try to change your sim with globe simcard,and its automatically send to your phone the completed settings to acess you in internet.gudlock
Feb 17, 2009 | Sony Ericsson W200i Cellular Phone
Setting up playstation
The PS50700 uses the PTK195 series chassis. You can switch the TV to the video mode by pressing MENU, press channel down 3 times to highlight "4 Channel", press MENU, press channel down twice to highlight "3 List and Labels", and then press MENU. The current channel will be highlighted, and you will press channel down until you go below channel 1, which is where the video inputs are (VID1, VID2, FRNT). To exit, press MENU, choose "Exit", press MENU and choose "Exit" again, or just wait until the menu times out. An easier way is to get a universal remote that has an "INPUT" button.
Sep 02, 2007 | Proscan PS50700 50" Rear Projection...
Dynex 32 in. LCD Flat-Panel HDTV Logo
189 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
