Question about Waring MBB518SS Professional Work Top Blender
I'AM TRYING TO DISASSEMBLE THE MOTOR FROM THE BASE AND NOT SURE HOW TO TAKE OF THE TOP RUBBER GEAR THAT DRIVES THE BLENDER
2 Suggested Answers
  • 3600 Answers
SOURCE: The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Posted on Nov 12, 2009
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
The black weel on top of the blender base that propel the blade in the bottom of the jug must be preplaced , where can I found one in south Africa?
Henzee, the part you are looking for is called the KitchenAid blender drive coupling. It is the little black rubber piece ontop of the motor base that looks like a crown with six teeth on top. The motor spins this piece which them spins the blades. It is a very common replacement part for the KSB5 blenders made by KitchenAid.
The part number you are looking for is 9704230, i am not aware of any places in Africa that sell the part but you can probably find someone in the USA that can ship it to Africa.
Here is a link to the video we have on changing the part out:
May 29, 2015 | KitchenAid KSB5 Professional Stainless...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Jan 26, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Nov 04, 2008 | Krups 239 Power X Plus Work Top Blender
Oster 6700 Blender
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives.
This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
Hope this might help Good Luck Loring
Oct 25, 2008 | Oster 6700 Work Top Blender
Krups 572 Power Xtreme VI Work Top
Repairing the blender:
My guess: You worked the motor too hard on your last blending session and it overheated. That will cause a thermal fuse inside to cut off. The blender won't work again until you replace the fuse but otherwise it should be fine. The fuse looks like a white diode and it will be attached tightly to the motor with a nylon strap (so that it can pick up the heat of the motor). The leads to the fuse are shielded with heat resistant nylon wrap. You will need to remove the rubber drive gear in order to remove the plastic house so you can work, although if you are really handy you might be able to at least test the unit by only removing the plastic bottom on the base unit.
To remove the plastic housing, remove the little rubber feet and then remove all of the screws on the bottom of the unit. You may need to buy a bit set for tamper resistant screws (I ***hate*** those), I don't remember. When the bottom is removed, you will see that the there is a screw head on the bottom of the central motor shaft. You can use a screw driver here to hold the motor from turning, then you can carefully use a pliers to unscrew the rubber drive gear on the top of the base unit (try not to damage the rubber). With the gear removed you can get access to the wires.
To test the fuse unit, just check its continuity. Short=good, open=bad. To further test, short out the fuse with a jumper cable and your blender should work.
EPO (Electronics Parts Outlet) in Houston, TX, has the replacement fuse unit. I don't know that they like mail order.
May 13, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Waring MBB518SS Professional Work Top Blender Logo
43 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
