Question about Sony Playstation 3 (PS3) Console
Purchased 60GB backward compatable PS3 ( used). Will not play games, PS2 or PS3, they freeze up.
    President:
  • 2,653 Answers
There are 3 main causes and solutions:
Software Issue (Restore the PS3 to factory settings via Sytem, Settings, Restore PS3
Dirty blu-ray lens ( take the PS3 apart and clean the laser eye carefully with a DRY q-tip.
Faulty / Failing blu-ray drive ( check and secure all of the cables to the blu-ray drive)
If the issue persists then more than likely you'll need to swap the blu-ray laser out with a new one.
There are a ton of guides on ps3hax.net and youtube.
Hope this info helps!
Posted on Oct 14, 2010
CAN YOU PLAY PS2 GAMES ON A PS3?
Only some models were able to play PS2 and PS1 games, these were early 20Gb, 60Gb and some 80Gb models. The 20Gb model number would of been CECHB**, the 60Gb model would of been CECHA** or CECHC** and the 80Gb model would of been CECHE**. Only these models are backwards compatible. The funcionality was removed from newer models and also the new PS3 slim model.
Hope this helps
Oct 30, 2010 | Sony Playstation 3 (PS3) Console
Tip
Playing PS2 Games on a PS3 - Check Backwards Compatibility
Not all PS3 consoles have the capability to play PS2 games. Sony have removed PS2 compatibility altogether from the new PS3 slim and the later version PS3s only have limited capability to play PS One games.
This Tip is written to help you determine if your console is backward compatible for PS2 games.
First locate the model number of your PlayStation 3 system by finding the bar code sticker at the back of the console. Underneath the bar code you will see the 11-digit serial number followed by the model number which begins with "CECH".
Models that have PS2 game compatibility are first generation consoles and the versions are 80GB, 60GB and 20GB. These PS2 compatible consoles will all have 4 USB ports which is another useful identifier.
See below for a breakdown of the model numbers that are compatible with running PS2 games;
1) Model No: CECHE01 - These are 80 GB models with 4 USB ports. (Please note 80GB models with 2 USB ports are not compatible).
2) Model No: CECHA01 60 GB models
3) Model No: CECHB01 20 GB models
Another important factor here is the PS2 games themselves.
Even if you have one of these consoles, a PS2 game may run fine on one version say the 60GB but may not work on the 80GB.
If you have identified that you have one of these consoles and want to check if a particular game is compatible with it use the link below. You can enter the exact console you are using - then enter the PS2 game you want to play;
http://www.us.playstation.com/Support/CompatibleStatus
This will give a definitive answer on compatibility between a particular PS2 game you want to play and the actual console you have.
I do hope this Tip has clarified the issues for you.
Please help by registering your vote using the buttons below and many thanks for using FixYa.
on Dec 28, 2009 | Video Game Consoles & Games
How to play ps2 games on ps3
Ok well here is the "Skinny" 1). 20GB has no chrome trim, no memory card reader and no wi-fi. Not manufactured anymore. Has the best backwards compatibility with PS2 games due to Emotion Engine (PS2's CPU) and Graphics Synthesizer (PS2's GPU) installed.
2). NTSC 60GB has the same backwards compatibility as 20GB version, also has memory card reader and wi-fi. Has a chrome trim.
3). 80GB - extended memory, but reduced backwards compatibility with PS2 games, it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played. Available only in NTSC regions.
4). 40GB - can't play PS2 games at all (all PS2 chips were removed), has 2 USBs instead of 4, no memory card reader, has wi-fi. Avalable in black and white colors. White is on sale only in Japan. Uses 65nm technology (lower power consumption). Improved cooling system. It's the latest version. 40GB doesn't support SACD.
5). PAL 60GB - reduced backwards compatibility with PS2 games. it has only Graphics Synthesizer (PS2's GPU). Around 80% of PS2 games can be played.
Wi-fi included in all models, except 20GB.
Feb 05, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3 won't let me play ps2 games. is there anything that can be done?
Unfortunately, no. Sony built the PS3 to only play PS3 games, so no backwards compatibility. Maybe in the future though, they might release an update.
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Will PS3 games play on PS2? Thank you
most ps3's unfortunately arent backwards compatible, however the 60gb consoles were made to be so. otherwise they can have chips put in them by people while being semi-legal is cheap and works well. so either have the 60gb console, or get a shark chip from your local supplier.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Can you play PS2 games on a PS3?
If you bought the original PS3 when it first came out and purchased the expensive one with the larger hard drive, it will be able to play *some* PS2 games. If you bought the cheaper one with the smaller hard drive or purchased your PS3 once the prices started dropping, it will have no capabilities of playing PS2 games, as Sony has decided to not continue making the system semi-backwards-compatible.
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
Can a ps2 play ps3 games
Some models can, the 60 GB model can play all PS2 games, the 80 GB can play pretty much all PS2 games, the lower end ones (I think the 20 and 40 GB can not play PS2 games). There is a rumor however that ALL PS3's will soon be able to play PS2 games with a software update.. that will not be available until a few months into the future, if ever.
Jul 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not play ps2 disks will play ps3 disks ok
playstation 2 games will only play on the 60gb ps3 the orginal console.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont play ps1 or 2 games or dvds it is the wrong region we are region 2 but it is region 3. How do we mend/change it.
well for a start are you sure its 60gb cos only the 60gb plays ps1 and 2 games but the dvds thats a bit odd
Jun 02, 2008 | Sony Playstation 3 (PS3) Console
Ps3
40gb is not backwards compatible, it cannot play some ps1 and ps2 games, the 60gb is though.
May 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
