I need a wiring diagram for an American Standard heat pump condenser model #6h0024a100a1
3 Suggested Answers
SOURCE: Wiring Diagram for Ruud Heat Pump
you should give more data as;
Brand of the air handler, the condensor and the thermostat
Posted on Jan 16, 2008
  • 116 Answers
SOURCE: Need low voltage wiring diagram for condenser
look on the indoor unit and see what they do you hav common from trans former yellow for compressor white for elect heat then reversing valve usually orange green for fan on the out door unit board you can tell what is common and what is for heat
Posted on May 09, 2009
Wiring diagram for 1960 american standard oil furnace model no.CS-195-60
Wow, you are going to have a heck of a time finding that. Try contacting American Standard. They may be able to help you.
Dec 04, 2017 | American Standard Heating & Cooling
I have a American standard ac model 7A0018-60A100A and would like to know the model no. of the condenser fan motor so I can replace it
All you need to know is that it is a 1/4 hp, 825 rpm. 1/2 inch shaft. That is if you are going to buy an after market motor. I have had to make new mounting holes when using after market motors on trane systems (just the way trane is) but not a problem. If you're getting it from trane you would only need the model number of the condenser.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 14, 2017 | American Standard Heating & Cooling
I need outdoor wiring diagram
Omg. Outdoor wiring diagram for what???? Lawnmower, vehicle, tractor, well pump, sprinkler system, condenser, heat pump, generator...WHAT MAKE?? WHAT MODEL?? WHAT??
Feb 20, 2017 | Heating & Cooling
Why does my American Standard heat pump compressor and condenser fan run when I have the thermostat set to emergency heat?
It's possible the "brain" thinks it can still supply some heat. Other wise there is a wiring problem or thermostat switch problem. Installed recently? Never used emergency heat before? What is your emergency heat type, gas or electric? Are you sure they are working. If not the "brain" senses and uses the only source available: heat pump. Thermostat? probably Honeywell? If so call Mfg customer service. Warranty on thermostat or heat pump? If so call customer service. Call your installer.
Feb 28, 2015 | American Standard Heating & Cooling
We need to find an owner's manual for our American Standard Heat Pump model # 4A6H6036B1000 AA. Can you help us locate one?
Please try with:
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Helpful?
Dec 20, 2010 | American Standard Heating & Cooling
I need a wiring diagram for a starndard residential split a/c system. Just the outdoor section is fine.
Hi, if this is just a split standard heating and cooling unit, and not a split heat pump, all you need to do is pull stat wire from the indoor unit control board to control the condenser with 5 conductors, but you will only use 2 wires for the control of the condenser. Normally, the red and white tie to the 2 control wires of the contactor. Back at the control board, red to red and white to the Y or yellow terminal. You will also need to set your disconnect box for your high voltage near the condenser, where you will be coming from your breaker to supply high voltage to run the motors and compressor. Very easy to do. If it is a heat-pump, you will need to pull at least 8 conductor thermostat wire to wire this up. I would also need to know what terminals and kind of thermostat you have, and if you are using heat strips for second stage of heat. When you say standard unit, you will only need 2 control wires from the indoor to the outdoor unit, along with the high voltage. Please keep me posted and let me know if you need more help on this. A wiring schematic wouldn't be needed if its just a standard condenser.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Nov 18, 2010 | Heating & Cooling
Filters for a C30A-054U-B condenser
Hi!
Try going to a local sheet metal fabricating shop or a heating/air conditioning shop. They can probably make some up for you. Usually a lot less expensive than trying to order some from Trane/American Standard.
Jan 01, 2010 | American Standard WCZ036F Air Conditioner
Need schematic for an American Standard A/C Model number 7A0030A1
American Standard and Trane are the same thing. The diagram you want is not complicated at all. Just straight cool unit. American Standard does not put low or high pressure controls on unit. You can get diagram on line At American Standard.com. Just what do you need to know? Very basic unit.
Jun 11, 2009 | Heating & Cooling
Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
202 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
