Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Make sure that lamp cover is fixed back on its position securely after lamp replacement, turn On tv to check. If still no picture or sound then check power/standby light is blinking? If yes, count it how many times it blinks after 3 seconds long pause and let me know to diagnose possible cause of problem. Thanks.
Hi, If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code. And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it. Still problem? let me know with exact model number of your Sony TV. Thanks.
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position. Thanks.
check the fan again with a flash light. I had this same problem and changed out the large fan behind the bulb...no more problem. my brother has the same tv and he has had to replace the fan at least three times.
