Question about LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin...
Door alarm is sounding even though door is shut. Just installed a new "door switch"but that has not helped the problem. Is there a reset button or something else other than to unplug the harness controlling the fdoor panel and alarm?
  • dfields_intl Oct 14, 2010
    I was smart enough to order two and tried them both. Thanks, for the "idea" but I got it. Others have posted to hold the lock button and the jet freeze button together for 3 seconds. That seemed to work to turn off the alarm, which is what I wanted. I hope this can help someone else, because it was the only thing I found that worked, although the problem seems to be a recurring and common problem with this door alarm.
    Problem Solver:
  • 87 Answers
Maybe the new door switch is bad , test it
Posted on Oct 14, 2010
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
Sunfire alarm sounding for no reason
Focusing on switches: Start with the door switches. Pull the fuse for the dome lights. Reset the alarm. Does it sound off? The alarm feeds off the dome light fuse. Driver door is first: Often they wear out first and give us grief like this. Unscrew and disconnect the switch first. Replace the fuse. Carefully close the door so you don't loose the wire in the frame(attach a string to it so you can fish it back out if it falls in). Reset the alarm. Does it sound off or not? If it does, it is other than the switch or the passenger door switch (if a 2 door or 2 other passenger switches if a 4 door). Repeat process until the switch is found or all are eliminated. Switches are cheap, so replacing them will not break the bank. Disconnect the fuse again, unscrew the bad switch. Unplug it. Plug in the new. Screw it back in place. Reconnect the fuse and try it again. Repeat as needed until you have either found it or just limited your search area. Most often you will stumble upon it- chaffed wires, look plugs, bad switches). Yes, there is more, but I see this as the usual suspect. If you go back into the alarm, disconnect the alarm first, then observe the dome lights with the fuse in. It just may be a faulty control in the alarm, which is out of my territory. Let us know what you find, but start with the smallest things first. Good Luck!
Mar 31, 2014 | 2001 Pontiac Sunfire
I have a 2005 Honda Odyssey Touring. I bought it used last year, so I am not too familiar with the car alarm in it. The alarm was fine until my battery died a few months ago. After the car was jumped, the...
Ok, try this.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
Dec 21, 2010 | Honda Vehicle Parts & Accessories
Sliding door alarm sounds constantly
there must be a switch some where , around the door to shut it off when door shut
May 10, 2009 | Chevrolet Uplander LS Cars & Trucks
Start button doesnt start the dryer
Sure sounds like a door switch to me. Is anyone slamming the dryer door? Was there a rubber bumper on the door that is now gone?
Mar 27, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Door alarm keeps sounding even though doors aren't ajar
The problem is the doorswitch of the freezer door. The door 'bump' which has to push in the swich doesn't push it in far enough. You can try and hold the switch an dpush it in with your finger and see if the sound continues. You can try to adjust the door, but easier is to glue or tape something to the door 'bump' so it pushes the switch further in. Hope this was the issue.
Jan 04, 2008 | Refrigerators
ginad, L&G missed the tolerance a little on the door switch. They do make a kit to correct the problem, I believe it's a little gasket that fits under the door switch. I use a plastic stick on, on the door itself, to solve the problem. As long as it's under warranty have the replair co. fix it. In the meantime just use a piece of tape to cover the door switch.....Catriver...post back
Jan 30, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LRSC26940ST 36" Side-by-Side Refrigerator w/ 26 Cu. Ft. Capacity, OptiChill Crisper & Jet Freezin... Logo
215 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
