Question about Samsung HLR5667W 56" Rear Projection HDTV
Samsung HL-5667W The picture has 5 vertical lines in it that are pink & green with ant input.Also the rest of the pic is grainy & flashing. The internally generated pic is perfect.What is possible my problem.
  • 144 Answers
RF signal you are receiving needs to checked and repaired if you are a using settop box as your RF receiver and it has AV options use them and check how the signal is if directly,if from antenna check cabling if not broken or corroded and check antenna receiver box for corrosion
Posted on Oct 14, 2010
HL-6187W, picture has vertical lines
If you can post a picture of what the lines are I can assist with the possible causes. I would assume digital board or DMD/ light engine
But a pic would help make it easier to figure out whats going on with the set.Respond to this same post for assistance.
Aug 07, 2012 | Samsung HL-S6187W 61 in. HDTV
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Green vertical bars on a Samsung projection
That is a problem with your main board - some of your inputs work fine and another is bogus. The tv input is not working because there could be a defect in your tuner. If you have cable try a different input for the signal.from the box. If you are using OTA, then use an external HD OTA tuner to feed your set.
Sep 09, 2017 | Samsung HLR5067WX 50" Rear Projection HDTV
It Quit!
call or contact samsung
Jul 04, 2008 | Samsung DLP HL-P5663W 56" TV
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
171 people viewed this question
Henry  Thomas
Henry Thomas
