Question about Fisher and Paykel Dishwashers
Bottom drawer showing F2 & tool. - Fisher and Paykel Dishwashers
  • Fisher and P... Master
  • 3,247 Answers
This means the rotor driving the impeller and wash arm is faulty or the rotor cavity has some obstructions. You will have to remove the rotor and clean the cavity or replace the rotor.
Please rate the solution if you find it helpful otherwise post a comment.
Posted on Oct 14, 2010
2 Suggested Answers
  • 3247 Answers
SOURCE: Bottom drawer shows code F2
The motor rotor is faulty or something is stuck in the rotor cavity.
Remove the filter plate and twist the rotor out to check. If it needs replacement you can get it from this site.
Also check the channel between the rotor cavity and the drain sump to make sure nothing is stuck.
This should fix the problem.
Posted on Oct 25, 2010
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Aug 19, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
The top drawer of our F & P dishwasher is showing and F2 fault, I have just fitted a new front control unit. F2 is the pump I believe, where on the unit do I find that?
The F2 fault implies there is a problem with the motor rotor which is located under the drain plate at the bottom right in the centre of the drawer. The rotor is actually driving the wash arms.
F2 does not necessarily mean you have to replace the rotor. It is also possible there is some debris inside the rotor cavity which is preventing the rotor from rotating at the normal speed.
Remove the racks and the wash arm. Twist the centre ring so that it disengages the drain plate. You can then pull the rotor out with a few back and forth twisting motions. Check if the cavity is clean. Re-insert everthing and start the wash cycle. If F2 comes in again, you will have to eliminate the cause by using the rotor from the bottom drawer and see if it makes any difference. You may then have to buy a replacement part.
good luck
May 26, 2011 | Fisher and Paykel 23 in. DD603H SS...
We have the error F2 showing on our dish drawers
normally the F2 showing on both drawers is unusual.
It is a rotor fault. Which means either the rotor that drives the wash arm and also works as a pump is either faulty or there is some rubbish stuck in the rotor cavity.
Lift the fiter plate out and open the rotor ring. Get the rotor out and inspect. If it looks ok or there was no noise when the F2 error showed up then the hall sensor mounted on the underside of the drawer is faulty.
The hall sensor can be hard to replace unless one has good experience in repairing dishwasher.
Nov 27, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Bottom drawer comes on makes rubbing noise then shuts off flashing f2
remove spray arm & filter, remove motor by rotating anti-clockwise and remove any dirt. Reassemble in reverse order.
Oct 23, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Feb 01, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Need users manual, (f2) fault
Hi and welcome to FixYA!
F2 means the motor is not being sensed to be rotating. Lift off the wash arm and see if you can spin the blue impeller by hand. If it won't turn, it may be frozen of ajmed by an object like broken glass. Sometimes also if you let the drawer sit unused for a long time (some people only use the top drawer) the rotor will freeze up. The part number is a 525884P if you need a new one, it requires no tools to change it. As for the user guide, you can get one free here:
http://fisherpaykelparts.net/index.php?blockitemid=29
Dec 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation.  The repair man  came and it took 2 minutes to fix.  The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed.  to fix it take out the basket, lift off the rotor arm and unscrew the knob.  Then just work the impellor around with your fingers until it frees.  It then worked perfectly.  We will use the bottom often from now on to prevent this happening again. By now the left over pumpkin pie will be a bit green!!
Nov 29, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
53 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
