Where can I get parts for Everstar Model mpk-10cr-1 portable AC Unit. I need the complete exhaust system.
  • Andrea DeSimone
    Andrea DeSimone Aug 31, 2013
    where can i get parts for the everstar mpk-10cr unit
    Problem Solver:
Parts can be purchased on amazon, click here and take a look Amazon com everstar air conditioner. I hope this was helpful. Cheers
Posted on Dec 27, 2014
Ed Phillips
  • 11 Answers
SOURCE: I have an everstar mpk-10cr and it leaks water out
This cap must be in place in all coolers I have seen. Frequently there is a gasket that is identical to the type used on a common garden hose. It needs to be clean and free of cracks. They only cost pennies. I don't understand what you mean by "I plugged it up but water did not go into the normal receptacle."
I will assume you mean that this is a manually filled unit and not attached to a water source. If that is the case give me more details on what you mean.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
  • 29 Answers
SOURCE: Compressor does not work
Empty the water tank, located at bottom of unit either left hand side or right hand side, normally removable.
all the best
Posted on Jul 05, 2010
  • 37 Answers
SOURCE: My Everstar portable air conditioner model#
Simple I believe...just run a weed eater line up the whole in the back where you have the clear tube. You can take the little back door off the power cord area to see inside where the water drips into the little tray before it goes down the hose tube. Water debris sometimes blocks the water from draining properely. The weedeateer line will clear the blockage and it will begin flowing again.
Posted on Aug 21, 2010
  • 37 Answers
SOURCE: I am looking for an air vent hose for an Everstar
http://www.supportuscenter.com/product.asp?specific=90
Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Jun 30, 2016 | Everstar Portable Air Conditioner MPK-10CR
Unit is making a grinding/rattling sound on and off with more use. How do I fix this?
Its a bearing problem could be the motor could be the fan this is a portable and dose need to level and sucured enough not to tip .
Grinding /rattling is the definition of a bad bearing.
Jun 02, 2015 | Everstar Portable Air Conditioner MPK-10CR
Need Instruction manual for MPK-10CR
You can find the Use & Care Manual for your Everstar MPK-10CR here:http://www.supportuscenter.com/documents/MPK_Manual.pdf
The warranty & repair services for this unit are handled by Midea. I would suggest contacting their staff for the part.
Contact for Technical Service USA:
Contact Person: Winston Sankey
Tel: +1-305-591-8460
Fax: +1-305-591-8451
E-mail:winston@mideaamerica.com
I also did a search for you on AppliaceFactoryParts.com. This may be the part you are looking for:http://www.appliancefactoryparts.com/search/part/1371698/146072
Best of Luck!
Jul 16, 2012 | Heating & Cooling
Everstar mpk 10 cr 1 manual, have an error code of P-1
It means that the little drawer for the water on the side is full of water or that it is not closed completly. In the water drawer there is a switch that makes it turn off the AC if it is running ,then it will give you a P1 code.
Make sure the water drawer is empty of water then. put the drawer back in carefully and gently, the switch that is built into the drawer will make contacts and your problem should go away. you might have to unplug the unit from the wall for it to clear the problem after doing the above steps.
Also here is a link to their site, Midea the company that makes these MPK-10CR units. For the owners manuel http://www.supportuscenter.com/documents/MPK_Manual.pdf
http://www.supportuscenter.com/pilot.asp
Sep 11, 2009 | Everstar Portable Heater/Fan
Jun 20, 2009 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
1,936 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
