Question about Blueant Supertooth 3
Having difficulty pairing BlueAnt ST3 with Blackberry Curve. Blackberry recognizes BlueAnt but does not accept code of 0000. Says "connection failed"
  • 214 Answers
Make sure the device is in pair mode, to put it into pair mode hold the green button down until you hear a language loop (with the device off). When you hear the language of your choice let go of the green button and press it once right away. When you hear that go to your phones bluetooth menu and enter pin code 000 when prompted. If this does not work do a hardreset on your phone by removing the battery while it is powered on, when it is back up research and repair and it should work.
Rylan
Posted on Dec 15, 2010
What is connection code for BlueAnt ST3
Pin code is 0000, make sure the device is in pair mode first
Oct 19, 2010 | Blueant Blue Ant 091193 Supertooth II...
How do I restore factory settings on my BlueAnt ST3. I have a new Blackberry and every time I try to pair them the Blackberry comes up with 'Unable to pair with BlueAnt ST3. Try again?' and every time I...
Here is how I got my Samsung to pair (on page 12 of the Blue ant manual):
Deleting all Paired Devices & Phonebook entries:
1. Ensure the SUPERTOOTH 3 is switched OFF, press
& hold the Volume Up (8) Button.
2. Whilst holding down the Volume Up (8) Button, press
the MFB (1) for 1 second or until a distinctive melody
is heard through the speaker, the software version will
then be announced. Once this occurs, please switch the
SUPERTOOTH 3 off for a minimum of 10 seconds.
All paired devices & phonebook entries have now
been erased.
Go back in and pair your phone, use pass code 0000 and let it reload your address book and you should be good to go
Sep 29, 2010 | Computers & Internet
I lost the passcode to my bluetooth i tried 0000 9999 and all others no pairing its a bluetooth 10799 and it goes in ciggerrette lighter and u can talk out loud please help dont want a ticket lol
How to connect or pair a Blueant Bluetooth handfree.
1. Switch off the Blueant:
i.e. push the microphone inside the Blueant.
2a. Press and hold the GREEN telephone symbol (or Accept) pushbutton
On the Blueant flat face for 8 seconds. (this makes unit go into “pairing” mode)
2b. at the same time switch Power On to the Blueant by pushing out
the microphone on the side of the Blueant.
3.The Bluetooth Indicator will turn a blinking red/blue,
when you see this, release the Accept Button .
The Blueant is now in “pairing” mode.
4. Get you mobile in Bluetooth search mode to pair with a new device.
5. The Blueant will request your mobile device for a password.
6. Enter the password= 0000 , the devices now will be paired.
7. Set the Blueant as a trusted/authorized device, if this is option in your phone.
Mar 18, 2010 | Blueant Supertooth Light Bluetooth Speaker...
I am trying to connect my blackberry storm to my blueant ST3. It asks me to enter my passcode, but when I do, nothing happnes and keeps asking to try again.
initially check whether both the devices are compatible when your pair them. Then try to give the same passkey on both the devices like 1234 in your blackberry and also same 1234 on your blueant ST3 and check.
Dec 29, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cannot pair blueant ST3 wih Nokia 6300
Reste the ST3 and then pairi again. It worked for me. Check this link:
http://www.myblueant.com/knowledgebase/reset/st3.php
Deven
Dec 25, 2009 | Blueant Blue Ant 091193 Supertooth II...
ST3 will not pair to any phone. Phones recognizes St3 but will not pair
I had similar problem with Motorola and Blackberry Perl. It seems that the device may have been used or demoed at the store, and had to be re-set to factory defaults. The procedure is simple.
  1. Make sure that the device is OFF
  2. Press and hold Volume UP and green ON buttom at the same time
  3. After reset, power the device OFF and wait for approximately 10 seconds
  4. Power the device ON, select a language, and follow voice prompts to complete pairing
Sep 06, 2009 | Blueant Blue Ant 091193 Supertooth II...
Blue Ant ST3 will not recognize 0000 passcode.
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Jun 11, 2009 | Blueant Blue Ant 091193 Supertooth II...
My g3 iphone says blue ant st3 password incorrect but it's the only one they give you...won't connect with my phone
Hi - I had the same problem setting up my 3G S. Here's the solution. In "Settings/General" set the Bluetooth to "ON". Turn your ST3 OFF by holding the green button until she says it's Powering Down. Now press and hold the green button ON until Language Selection (British English) option. Select language by pressing green button again. Next she will say "Device Found-Paring Successful-Enter password 0000". Enter 0000 and your phonebook will start downloading. There ya go!
Jun 07, 2009 | Blueant Blue Ant 091193 Supertooth II...
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
May 04, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Blueant Supertooth 3 Logo
581 people viewed this question
Top Blueant Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Blueant Cell Phone Expert? Answer questions, earn points and help others
