Question about GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore series Model # 69051fan squeaks
Fan in unit squeaks, sometimes just a couple turns, other times can run like that for 10 or more minutes, service wont come out since this is a intermittant problem, and no plans if it is not heard to confirm.
  • 110 Answers
Evap. fan mtr are always tricky if the are intermittent. you need to record the sound when it happens and make sure it is coming from the freezer. make a record of how many times it happens in a 24hr period all this will help the tech. and don't take no for a answer from the tech most service calls are good for 30 days
Posted on Jun 03, 2008
Is a small amount of brown moisture coming out of A/C w/cold air & slightly squeaking fan upon yearly startup on kenmore model 253.70101 acceptable : should i run it longer than 1 minute.
Brown is rust.
Painted metal outside for 2 yrs eventually rusts (ergo: brown drips) The fan is exposed to heat/cold/wet and the sintered bronze bushings may have lost their lubrication and/or the shaft is corroded, causing squeaks. Take the case off and try to lube the shaft bearings with oil, not WD40.
May 13, 2014 | Heating & Cooling
Kenmore AC window unit model 253 70151 cuts on and off.
Circuit board could be the problem but compressor needs to be checked and there might be a loose electric connection or high voltage causing the ac to trip
Apr 04, 2014 | Heating & Cooling
The engine in my automatic '91 Integra intermittently makes a loud squeaking sounds to be coming from the left side of the car under the hood. It is not the fan/fan belt, as the noise...
are you sure its not your fan belts? because if fan belts are not turning, it means that the engine is off. check if the tension in your fan belts are still ok. if not, have it re tensioned. if noise is still present, have it changed.
Aug 11, 2011 | Acura Integra Cars & Trucks
Kenmore 80 series washing machine model stopped spinning
Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
Mar 21, 2010 | Kenmore Washing Machines
Dryer shuts off after 5 or 10 minutes
repl/ thermsitor if avaiable if not repl/ hi limit thermostat on top of ignitor
Dec 29, 2008 | Dryers
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
you can check a lot of things. the motor itself, the rollers on the back, and the main bearing at the center of the drum. you can apply any lubricants to all of those rolling parts.
Feb 12, 2008 | Kenmore 84152 Electric Dryer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
