Question about Microsoft Bluetooth 5000 Mouse
Need microsoft mouse bluetooth 5000 passkey - Microsoft Bluetooth 5000 Mouse
    Scholar:
  • 38 Answers
The official documentation says:
If you are prompted for a passkey, enter "0000" (for added security), or choose no passkey. This mouse will not work with any other passkey.
Posted on Oct 14, 2010
3 Suggested Answers
SOURCE: I have a Microsoft Bluetooth Notebook Mouse 5000 and i need to change the battery. I cant find any latch or button to open the mouse to put new batteries in it! I looked on the MS site and found nothi
There is actually no release button on my 5000. Between the white on-off button and the bluetooth synch button there is a finger notch. If you put your index finger in the notch (pointing toward the base of the mouse you can put your nail under the lip and the batter compartment opens right up. There is a horizontal slot in the battery cover - trying to pry that open does not work. The whole thing is well-cloaked but surprisingly easy when you figure it out!
Posted on Dec 22, 2009
KeithHL
  • 67 Answers
SOURCE: how can i remove the battery of my microsoft mouse 5000
I found this page about that particular mouse: if you look at the images part way down the page (may have to scroll down a bit) the middle image is of the bottom. There is a little trap door for the batteries. There is a little catch you just push on the release and the door opens. Very easy.
Posted on Jun 05, 2010
How can i remove the battery of my microsoft mouse 5000
May 31, 2010 | Microsoft Bluetooth 5000 Mouse
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
What is the pairng code for mouse 5000 ?
  1. Windows XP
  2. Click Start, and then click Run.
  3. Copy and then paste (or type) the following command in the Open box, and then press ENTER: services.msc
  4. Double-click the Bluetooth Support service.
  5. If the Bluetooth Support service is stopped, click Start.
  6. On the Startup type list, click Automatic.
  7. Click the Log On tab.
  8. Click Local System account.
  9. Click OK.
  10. If you prompted to restart the computer, click Yes.
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
    A Microsoft Bluetooth mouse does not require a passkey to connect to the computer. If you are prompted for a passkey, select No passkey. If you do not get the No Passkey option, try to enter 0000 as a passkey by using your keyboard.
Apr 20, 2010 | Microsoft Bluetooth 5000 Mouse
Where can you buy a replacement usb adapter for a microsoft wireless desktop mouse and keyboard 5000
If this is a bluetooth mouse and keyboard, just exactly what I'm reading and your computer does not have bluetooth built in then this is what you need to buy.
http://www.amazon.com/IOGear-Bluetooth-Micro-Adapter-GBU421/dp/B0018O9JIG/ref=dp_cp_ob_e_title_1
You can get this at your local BestBuys or online.
Don't forget to vote for me, and give me a good rating.
Mar 25, 2010 | Microsoft Wireless Laser Mouse 5000
How do I open the microsoft 5000 bluetooth mouse to change the batteries?
Press the small silver button on the back of the mouse. When you press this in, slide the top of the mouse backwards and you should see the battery compartment inside. Hope this helps!
Oct 24, 2009 | Microsoft Bluetooth 5000 Mouse
GOT ONE OF THESE WITH NO DOCUMENTATION AND NEED THE DEFAULT PASSKEY TO USE IT. HELP!
That mouse doesnt require a passkey. Select no passkey while setting up. For more info
http://support.microsoft.com/kb/952818
Jun 13, 2009 | Microsoft Bluetooth 5000 Mouse
Microsoft blue tooth 5000 mouse stopped working
Deleted the mouse from bluetooth and then added again.found info at
http://support.microsoft.com/kb/894035/#top
Jun 13, 2009 | Microsoft Wireless Laser Mouse 5000
May 27, 2009 | Microsoft Bluetooth 5000 Mouse
Microsoft Bluetooth 5000 Mouse Logo
557 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
