Blowed right speaker channel - Audio Players & Recorders
  • 144 Answers
Depending on manufacture you can replace the sound IC/fuse that probably blew if you know how to handle a soldering iron and solder ******
Posted on Oct 14, 2010
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
Right speaker channel doesn't sound clear anymore
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Nov 17, 2014 | Audio Players & Recorders
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
Sansui au-999 static right speaker then blows right speaker fuse
so meaning the right speaker needs a filter which frequency is it normaly u using a certain yf for a certain type of speakers and if you dont the fuse or what ever will go
Fuse for right channel keeps blowing
Right channel needs repair, output transistors is my guess. Or you have a bad speaker, if it plays at low volume then blows when turned up.
Mar 18, 2011 | Audio Players & Recorders
When right channel is wired it shorts out the power supply. Aragon 8008 when powered up without input and output, no problem. When connected with speakers and line level feed in, the left channel works...
Fuses blow when there is an overload caused by a short circuit. If the speaker you connect up to the amp causes a short. There is either a shorted part in the speaker or the wires to it are touching at some point. Assuming you can sort out the speaker issue and connecting a good speaker with good wiring and it still causes a short and blows a fuse. Then it's likely the output device(s) in the right channel have developed a short themselves. Perhaps as a result of being connected to faulty wiring or speakers.
Jul 18, 2017 | Aragon 8008 MK II 2-Channel Amplifier
Left side crackling noise Blown channel?
Would check your balance settings. Make sure your not balanced more to left than right. Next i would try to swap over one of the speakers from right side to left to see if it crackles. If not replace left side speakers.
May 19, 2009 | JVC KS-FX200 Cassette Player
No right channel output after fuse blow out
Sounds like the power transistor(s) on that channel burned out. Needs service.
May 04, 2009 | Audio Players & Recorders
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
37 people viewed this question
 Grubhead
Grubhead
