Question about LG WM0642H Front Load
My washing machine that is stopping at the rinse and spin cycle and the water is not draining out. I have drained all the water out of tub from tube at bottom and restart washing machine and it does it again. What can I do to stop this from happening.
    Brigadier General:
  • 3,513 Answers
Please check the bellow link to troubleshoot your problem to your machine:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#Itwontdrain
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 14, 2010
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
My machine stops working after the rinse cycle and won't go into the spin cycle. The water stays in the tub and will not drain. I have unplugged and replugged the machine just to make sure. I wanted to see...
It sounds like the Drain pump may have stopped working. After the rinse cycle, the machine should drain the water and start spinning. The Drain Pump should be at the bottom of the machine.
Feb 22, 2011 | Roper RAS6233KQ Top Load Washer
Fws445rf1 washer didnt stop filling and flooded my apt and it doesnt aggitate when it is washing,the whole thing just spins inside instead of moving back and forth,what are the most likely reasons for...
if it's a top-loader, then the water level sensor is probably failed! if an older machine- there's a plastic tube (which you can't see from the outside) that measures the column of water in the tub of your machine, and triggers the agitate and spin, and rinse cycles of your machine.
when it's in wash cycle the water level is lower, then it spins and drains and the rinse cycle pumps in more water (makes sense!), then drains & spins, then re-rinses at the same water level. your water level sensor is defective, probably. allowing it to over-fill.
it detects the water level as 'spin' and doesn't agitate!
my theory- no guaranty! if it's old get a new washer or a good used one! this is not a problem i've encountered, just a guess. good luck!
Apr 17, 2010 | Frigidaire FWS445RF
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
LG WM0642H Front Load Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
