Question about Philips Magnavox 9P6034C 60" Rear Projection Television
TV keeps turning off
I could be watching it and it will cut off in the middle of the show I am watching. Try to cut it on and and it shuts back off again then after about an hour it works again.
  • 137 Answers
You must Check Lopt Line output Transformer , Sounds it getting hot , then trip. If you are not a tv tech take it to one because there is heave high voltage there.
Posted on Jun 29, 2008
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
TV shuts off after watching netflix or it starts to reboot
I have a similar problem with HULUplus - I think I'll return the TV to WalMart and try another brand. It's the second VIZIO I bought in the last 5 mos. that has had issues. The first TV had popping (sounded electrical) sounds, also cut out sometimes. Would U-Verse have something to do with it? That may be a dumb question, but who knows?
Jan 22, 2013 | Vizio VW42LF 42 in. LCD HDTV
Keeps cutting off while watching tv
If the set shuts off then tries to turn itself back on then I suspect the lamp. The lamp part number is BP96-01472A. If it just shuts down and then you are able to turn it back on, then in most cases you have a bad digital board. The part number for the main/digital board is BP94-02262D...Please take a few moments to rate my answer. Thanks...
Nov 24, 2009 | Akai PT50DL24 Television
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
Rear Projection TV Cuts out Need to wait and then turn back on?
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
My tv keeps turning off after 5-10sec.
Hello Onna76,
Ok this is a VCR/DVD Combination TV. First of all let's look at what your description says: "The VCR part has been removed" dou you mean that the VCR mechanism has been taken out or do you mean that the VCR mechanism was removed and then put back in? The reason I ask is because on the VCR circuit board there is a position sensor which senses the position of the gears on the VCR mechanism, when the gears are positioned in a certain way the sensor tells the power supply to remain on, however if there is a misalignment the set shuts down. This is what is happening in your case. If the VCR mechanism was moved and then replaced, make sure that the sensor and gear are aligned properly. the protrusion on the sensor should go into the grove on the gear and the middle of the gear should go into the middle of the sensor. This will allow the sensor to track the gear and take care of that cutting off problem.
I hope this helps,
Thank you,
Mar 03, 2008 | Televison & Video
Green Screen
Your picture tube is bad,pull back off/ unplug crt broad on neck of tube make sure it does not touch anything ,turn set back on if set stays on tube is shorted!
Dec 18, 2007 | GE 13R100T 13" TV
A black box
It's in closed caption mode. Turn off the closed captioning, and it will go away.
Dec 02, 2007 | Zenith TVBR1322 13 in. Combo
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
