Question about Frigidaire Ovens
Model No: Frigidaire FCLMO30 3000w..have just acquired this model, but find the instructions are not clear on using the oven. tried baking some scones only to find that the tops did not cook andthe bottom overcooked?..
Master_Tech
  • 770 Answers
SOURCE: Frigidaire Oven Problem
please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
Posted on Jan 28, 2008
  • 1073 Answers
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Posted on Apr 12, 2008
EllaWatson25
  • 725 Answers
SOURCE: FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Posted on Aug 24, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire gas oven - model FGF366AWA - doesn't get hot inside
Yes it could be the thermostat, but what you need to find out and it is difficult to do, is determine what is cutting your gas back off.
The thermostat could be doing that but the most likely cause is the ignitor.
http://www.appliancepartspros.com/part_details.aspx?part_id=2150412&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d111760%26diagram_id%3d335207
The amount of electric going through hte ignitor is what tells the gas valve to stay on. When the ignitor gets old it does not pull enough power anymore. The the burner lights for a bit and then cuts out before it should giving you some heat but not enough. It just sits there and cycles...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Jan 01, 2010
Testimonial: "Tips were helpful and response was very quick."
Macmarkus
  • 2605 Answers
SOURCE: Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Posted on Jun 18, 2010
Where is the speed bake switch located on a Frigidaire oven
Hello friend, thank you for your post!
Based off the information you have provided you need to know the location of the speed bake switch inside of your Frigidaire oven. I would be happy to provide you with that information, if you can provide me with your model number. You can locate the model number on the serial tag and that can be found on the bottom drawer frame. Once I have that information I would be able to assist you further. -Matt
Dec 13, 2015 | Frigidaire Ovens
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Sep 27, 2014 | Frigidaire 24" Single Gas Wall Oven with...
How do I Unlock the Frigidaire speed bake oven door
Hi Friend, thank you for your question!
I understand you would like to know how to unlock the door of your Frigidaire oven. May I please have your model number? You can typically locate the serial tag (which lists your model number) inside the storage drawer, on the right side. With this information I can provide you the correct instructions. Thank you! - Z
Jun 05, 2014 | Frigidaire Ovens
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
The elements will not heat up on bake.
The problem is the Bake heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 02, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
Require Electronic Oven Control Guide for a drop in/slide in electric range model Model CFES365EC Frigidaire range self cleaning free standing
the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
Sep 16, 2009 | Frigidaire Ovens
Aug 24, 2009 | Ovens
Dont have manuel instruction i want to cleane my oven witch self cleaner
HI, you can retrieve your manual digitally by using the link below.just click the link provided below and, enter you complete model number. Once you enter your model number, you will be directed to the manual download page.
CLICK HERE
Jun 09, 2009 | Frigidaire FEB27S5A Electric Single Oven
select timed bake
Apr 11, 2008 | Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
