Question about Craftsman 25cc Gas Line Trimmer
My problem is that there is a third small line coming out of the carburator, just beside the main fuel supply line. Where dos it go?
    President:
  • Craftsman Master
  • 1,545 Answers
This is the line that carries the old gas/air that is in the carburetor back to the fuel tank, and it connects onto the shorter nipple of the purge/primer bulb where it is then pushed back into the fuel tank. The longer nipple on the buob should have a line going directly to the fuel tank. The filtered fuel line goes directly from the fuel tank into the carburetor (fuel pump side...that is the side without the vented cover). The vented cover side is the metering chamber side and that side is where the purge line you speak of should come from.
Posted on Oct 14, 2010
Testimonial: "Thanks, it was the info I needed. Great help."
  • pagueal Nov 10, 2010
    Yours is the most thorough and complete explanation of the fuel lines routing that I have seen. It really was helpful.
    Alan
Need a diagram on how to connect the fuel lines back on a ryobi 725r trimmer
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Oct 01, 2009 | Garden
Routing of fuel lines
Typical fuel line routing2.gif is:
Oct 01, 2009 | Craftsman Convertible 14" Gas Line Trimmer
How to connect gas hoses
Sep 29, 2009 | Garden
I have a ryoby 31cc weed eater I need a diagrm on the corect posision of fuel lines
Sep 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to hook up a carburator on a weedeater with a primer bulb
Sep 18, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
The fuel lines were brittle. I need to know how they hook up to 33 cc
The typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
Fuel line routing for RYOBI Models 705r and 725r
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Garden
Troybuilt 2 cycle fuel line routing
Sep 04, 2009 | Garden
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Craftsman 25cc Gas Line Trimmer Logo
387 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
