Question about Whirlpool GR448LXPQ Electric Kitchen Range
The oven takens forever to heat to right temp. It just stays warm for 30 minutes or more.
    Problem Solver:
  • 87 Answers
New elements
Posted on Oct 14, 2010
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
It takes forever to cook anything in the oven I set the temp. the buzzer goes off and I put in the dish in. but it takes too long to cook.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
I have a Viking Dual Fuel Range. The large oven
if your elements are exposed and not hidden, check to see is there is food particles may be baked on the element, you might need a new element, cheap to purchase yourself and install if handy
Sep 03, 2009 | Kitchen Ranges
Oven turn's on, keep's heatings at a higher temp.
This is failed communication between the EOC and the temp sensors located in the oven. i recommend testing the EOC(break point test on the pins) for its operational value and the temp sensors as well. replace any component that doesn't register.
I would also inspect the oven temp sensors for welded harness and fouled housings.
In most cases, this will be a EOC issue.
May 24, 2009 | Frigidaire 30 in. Electric Gallery Series...
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven will not heat to right temp
you can calibrate you oven try presiing and holding the bake button for 3-5 secs. it should beep and put a 00 in the display. using the temp up or down arrows you should be able to adjust ther temp to a max of 35 degrees + or -. after setting to desird 25 presss start and that setting will be ingrained in the memory forever(or until you change it again)power failure will not effect it either . of that doesnt work gimme the modle and ill ck further
Mar 08, 2008 | Ovens
Whirlpool GR448LXPQ Electric Kitchen Range Logo
112 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
