Question about E-Machines eMachines Desktop PC
I have tried to installl the internet on my desktop. the cable company says i need a network interference card installed
  • E-Machines Master
  • 1,183 Answers
HI,
Check in device manager to check if there is any question mark next to Ethernet controller . if there is then you would have to install the network card driver.
For your reference attaching i picture how it would look like
You can use the following link to download the drivers for the Ethernet controller. Note: You would have to select the correct model and operating system for which you need the drivers.
Download Link
Thanks for using Fixya
Proton
Posted on Oct 14, 2010
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
What ethernet driver do I need for dell optiplex gx260. There is no ethernet card. Just a slot for the enthernet cable.
check the Device Manager,
Go to Desktop/My Computer/Right Click/Properties/System Properties/Hardware Tab/Device Manager/look for Network Adaptor/ Expand it by clicking the + sign/Do u c any Ethernet Adaptor there or any yellow ? mark there....
If u dont c any Netwrok Adaptor then u dont have a network card installed in ur PC, if u have one then it will show up there, and if u dont ahve the correct driver or if's not installe dproperly then u will have the yellow ? amrk or an ! mark....
then in that case u will need the corect driver for the card to work....normaly Windows installs the required drivers for netwrork cards.....
Dec 17, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Dimension 4700C Desktop PC, internet issue.
Try and test the computer and modem connection by hooking it up directly by an ethernet cable..
If the internet connection stays solid when cabled up..
Then try either changing or removing the wep or wpa encryption on your wireless network, and seeing if that allows the computer to stay connected.
Also try disabling the firewall on your computer, and also on your modem.
Oct 30, 2009 | Dell Dimension 4700C PC Desktop
Hp dc7900 internet receving fail
have you tried getting a network card for your computer that might be the problem or it could be with the driver that the card runs on try updating the driver on the network card that you have installed on your computer.
Oct 28, 2009 | HP Compaq DC7900 PC Desktop
How do I replace the nic card in my computer?
a Nic card is a simple device (Network Interface Card) presumably a desktop machine I suppose. Just go to a local ABC warehouse or Walmart and by a new Network Adapter "NIC" PCI card and install with the drivers provided. Should be around $12-25.00 depending on the model... this should work:
http://www.walmart.com/catalog/product.do?product_id=2067722&findingMethod=rr
Aug 04, 2009 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Can't get it to work
I had the wireless working with dynex card before the virus hit the computer. The virus is fixed, but the internet does not work.
Feb 28, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Network adapter
your network adabet driver is not installl
do you have driver install it
Aug 10, 2008 | Dell Dimension 2400 PC Desktop
Dimension 4550 10 100 Network Problem
chk in the device manager if the netwrk card is listed correctly.....also try disconnecting & reconnecting the cables
Jun 23, 2008 | Dell Dimension 4550 PC Desktop
E-Machines eMachines Desktop PC Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
