Question about Sharp R-1870 Convection/Microwave Oven
I have a Sharp Platinum Collection 630D microwave--about 8 years old-- that has timer problems. It does not display the numbers I set it for and doesn't show the count down. Can this be fixed? Thanks. Linda
  • 619 Answers
SOURCE: Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Posted on Jan 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Over the Range
When you hit Start, does the oven lamp come on but not the fan or turntable?
That would be a problem with the secondary (bottom) door interlock switch or its mount.
Posted on Aug 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: R-1490 fan doesn't run or unit doesn't heat
That would be a defective secondary interlock (bottom door switch) or its mount.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 17, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-530ES microwave oven stopped working
You have a bad secondary interlock (lower door switch) or its mount is damaged or out of alignment.
You will need the
Posted on Dec 28, 2008
The display light is not bright.
It likely needs repair of the backlight circuitry.
Assuming your model number is R-630D-something, the service manuals here and here will help you.
Jan 30, 2013 | Sharp R-630D Microwave Oven
Sharp R-630D Display Problem
Usually switching off and removing plug for couple of minutes solves this problem if not then its going to need replacing as a resistor has probably gone on the display board unplug it then let me know what happens ok
Apr 21, 2008 | Sharp R-630D Microwave Oven
The display is blinking and I can not start the microwave
see the flow chart and proceed according: you can have problem faulty board or sensor.
Jul 13, 2012 | Sharp R-630D Microwave Oven
Display lights on the door out
This can usually be repaired economically, but we would need the full model number to give you an estimate and further free info.
So please post a new help request with full details of your failure, as well as the full model number.
Jun 23, 2011 | Sharp R-630D Microwave Oven
Sharp Microwave Lights Up, But Won't Rotate or Cook
Hi. I would suggest checking out the door switches. There are usually 3. If one of those has failed then the microwave won't operate because of safety reasons. Best to replace all three. If the display on the unit is still fully operational I'd say go for the repair.
Mar 18, 2009 | Sharp Microwave Ovens
Sharp R-630D
Hi, sorry fixya site is having some problems the experts are not recieving the emails with your response so we have to do it the long way and it takes ages going through all the posts we have helped on.
Ok then if the display is faint then the chances are its going to be the lcd display thats the problem as the display is working its just not lit up so replacing this will solve your problem but its not an easy job to do and is extremely dangerous microwaves are one of the riskiest things to work on as they give of radiation so breaking any seals can cause damage to anyone standing next to the microwavy.
The display is usually lit up showing the numbers but as you can see them faintly this tells us the circuit is okay and not shorting so its not anything drastic but replacing would be difficult.
If the inside is fine where the runners are then the chances are it would be worth getting repaired but if the paint has worn away or any rust is visible then the safest option is to replace it ok.
Let me know if you need further assistance ok
Repair
problem is a blown fuse inside the display door.
Jan 17, 2008 | Sharp R-630D Microwave Oven
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Sharp microwave r630ds
The problem is in the display control unit mounted in the outer door panel.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 23, 2007 | Sharp R-630D Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
189 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
