Question about Yamaha NP 30 76 Key Lightweight Digital Grand Piano with Touch Response
When pressing down on a key, it sometimes work, and sometimes doesn't.
  • Yamaha Master
  • 5,603 Answers
The key contacts are dirty... They are likely conductive rubber pills pressed onto traces on a circuit board. There will be two contacts per key to use for velocity sensing.
Disassemble and clean the black rubber pills that are usually in silicone rubber domes AND the corcuit board traces using ONLY 99% isoprophyl alcohol and QTips. 99% is a bot hard to find so look around for it.
Posted on Oct 14, 2010
Yamaha dxg 500: some times have to press piano key multiple times to get sound. It's not always the same keys that work that way.
Yamaha's have little rubber "contact strips" that run under the keys. These strips have little rubber buttons on them, exactly like your tv remote. When you push the key down, it pushed the rubber button down and make an electrical contact. These buttons eventually fail and separate where the bottom of the button meets the strip. You have to replace the strip (different sizes, depending on where on the keyboard it is) but they aren't cheap. You can find them here http://syntaur.com/yamaha_psr.html but sometimes you can find someone selling them on ebay cheaper. If you only need a single strip, or maybe two, it's probabaly worth it. More strips than that and you may find it cheaper to buy someone's broken keyboard on ebay and take the strips out, especially if it's broken for a different reason, like won't power up.
Sep 23, 2017 | Yamaha Music
C key is sunken down. The hammer action counterbalance isn't working properly
Check it again. It may have something dragging on the key, maybe something sticky like soda or juice residue. You can also try swapping out the key with another C or F key that is less used. Good luck!
Sep 24, 2016 | Casio Privia PX150 Digital Piano
I acquired a used, but well kept, good condition Yam CVP-5 clav. Some keys work sometimes, sometimes no keys work. I tried the programming and instrument buttons. Jody Bailey Newcastle Australia
I expect, assuming you did the re-boot routine, that the problem is your key contacts. Contact Yamaha for your nearest service center. Here's the link-
May 18, 2016 | Music
After having been in safe waterproof storage during cyclone season I,ve unwrapped my korg pa 500 and plugged it in but it doesn,t boot up .The sreen is lit well with simply "Korg"...
First thing... make sure you are using the KA320 power adapter with it. We will work from there.
The unit probably is sensing an error of some type. Check these things: That NO key or button is STUCK down. Next, one could try reseating the memory sticks if you have expanded memory.
Let me know if you find a button or key is stuck down (not uncommon when unit has been wrapped) or you are using the wrong power adapter.
Jun 10, 2011 | Korg PA500 Professional Arranger 61 Key...
Suzuki HG425E All the contacts for the keys are in bad condition and need to be replaced. Where can I buy such assemblies?
The contacts probably just need cleaning. Often they are conductive rubber "pills" in silicon domes that the key presses down against a circuit board under the keys. Clean the pills AND the circuit traces they press down on with ONLY 99% isoprophyl alcohol and Qtips. Be gentle in cleaning. Most of the work is accessing the contacts. Note these contacts do NOT for a low resistance contact as the electronics doesn't need a good contact. There are two per key to implement sensing key velocity. Sometimes the contacts are coencentric with a pill inside a ring of conductive rubber. The conductive rubber is always black.
Apr 21, 2011 | Suzuki S350 Mini Grande Digital Piano...
Roland Piano 600 HP 600, out of 76 keys, Keys# 4, 9, 10,11,12,13,14,15, 23, 38, 74 will not play( no sound). Any ideas? Everything else works. Have taken no actions to fix yet.
There is a rubber "bubble contact" strip under the keys, and pressing on a key pushes the bubble down, which makes contact with the circuit board underneath. Any foreign matter that gets in the way of this contact will render that note unplayable, and that is likely what has happened. You can remove the keybed, remove these strips, and clean the board with rubbing alcohol. Don't use alcohol on the bubble strips, as it is not good for the rubber.
Sometimes, you can simply tape a small piece of cardboard, like from a cereal box, onto the bottom of the key where it pushed on the bubble, and this can fix the problem.
The bottom line is that you will have to remove the keybed, and that may be a daunting procedure unless you're used to that kind of work. So you may want to just take it to a service center. You can get parts at www.syntaur.com. Good luck!
Feb 25, 2011 | Roland Ep760 76Key Digital Piano
Hello, I have a CTK 601 keyboard and some key do not sound, I turn it off and on again, sometimes it works sometimes it does not. This is a set of 7 keys on the right part of it. pls advice
Key contacts are dirty. The contacts are conductive rubber pills that get pressed against circuit traces on a board undder the keys. Clean the rubber pills AND the circuit traces with ONLY 99% isoprophyl alcohol and Q Tips. Be careful of the cables when opening the unit. There is also a slight chance that a cable has come partway loose internally. If you are uncomfortable with opening the unit and keeping track of all the screws, better take it to a repair shop.
Nov 29, 2010 | Casio 76 Key Smartmedia Keyboard
1 key is not producing any sound its D.. n the midde c.. is sumtimes producing a sound n sometime its not.. kindly tell wat has happend to my synth psr i425
Key contacts are dirty. You will have to service the unit. The contacts (two per key) are conductive rubber "pills" that press down on circuit traces under the keys. Use ONLY 99% isoprophyl alcohol and Q Tips to clean both the black pills in the silicone domes and the circuit traces themselves. Be gentle when doing this. When opening the unit, be careful of all the cables as they are easily damaged.
Nov 01, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Nov 29, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Keys don't work in random pattern formation
The keys are scanned in a matrix. It sounds like two of the matrix lines are broken. They may be broken on the board which the keys contact. These are often conductive rubber "pills" pressed onto finger like patterns of circuit traces. The traces have a black coating in the contact area. If the keys have been "mashed", sometimes the board is cracked. IF the crack goes through one of these contact areas, that is fatal. That board needs to be replaced.
A loose cable where two wires of the matrix aren't contacting would do it as well.
Dec 02, 2008 | Roland Music
Yamaha NP 30 76 Key Lightweight Digital Grand Piano with Touch Response Logo
90 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
