Question about Seth Thomas Pacconi Turntable
I see there are other people who have the same problem I have. The speed is too slow on mine. The platform is loose so the belt could be off. The 78 speed seems to be okay. How can I fix this?
  • 144 Answers
Sounds like your belt is either stretched (replace) or has become sticky greasy(remove clean and refit)
Posted on Oct 14, 2010
Turntable runs at 45 spped when set to 33 1/3 and at 78 speed when set at 45 speed
This sounds like the belt, if it is a belt drive model, has slipped to the wrong position on the motor post. You should be able to set it back up right. As long as the belt is not worn out.
Any recordings at 45 can be converted to 78 using the software. There should be an option to do this. This applies to all other speed settings too. You can convert 33 to 45 etc using the same thing.
Jun 02, 2017 | Sony PS-LX300USB Turntable
Thomas Pacconi Model TPC-MSE-800 turntable runs slugglish. 78 runs fine but 45 or 33 runs slow. I removed belt cleaned it and platter. I put a drop on oil still same problem. Do I need a new belt? This is...
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Dec 16, 2010 | Seth Thomas Pacconi Turntable
I have a proform 740CS, it sometimes slows way down, if I step off it will sometimes speed up much faster than what it's set at, but then slows down again when I step back on. Other times, it remains...
Please LUBE very well the Walking Belt.
2) Inspect the drive belt motor, if is loose, Retight.
3) See if there loose wires for MOTOR.and retight.
4) The walking belt LIFT wiht your finger must be 2-3"
otherwise Readjust with the allen screw rear.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How To Lubricate Treadmill
Nov 22, 2017 | Proform 7.0 Crosstrainer Treadmill
Celcus washing machine makes a banging sound when starting on spin and slowing down from spin
It could be caused by loose or damaged bearings or even damaged belt. You might have to replace worn out belt and bearings. Also find out if the washer is sitting on an uneven platform. Make sure the floor is even and the machine is not tilting.
http://www.washingmachineadvisor.com
Nov 22, 2010 | LG WM2077C XL Front Load Stackable Washing...
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
My tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Apr 10, 2010 | Proform Exercise & Fitness
Ground speed slows under pull at high variable speed settings.
Take off the plate around the shift lever between your legs and take a look at the belts. Most likely they will be in poor condition. You can even leave the trans in neutral, start the engine and move the speed selector through the gears and observe the belts in action. They do the same in neutral as in gear when you let out the clutch with the engine running. You should be able to see what the problem is, It will either be one or both of the belts or possibly the needle bearings in the vari-speed pulley itself,
Jun 01, 2009 | Mtd Garden
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Uneven speeds
belt came loose please help[
Jun 24, 2008 | Sony PS-LX250H Turntable
Seth Thomas Pacconi Turntable Logo
371 people viewed this question
Top Seth Thomas Audio Players & Recorders Experts
Dennis Key
Dennis Key
Vito Vacirca Jr.
Are you a Seth Thomas Audio Player and Recorder Expert? Answer questions, earn points and help others
