Question about Dishwashers
No power to my dishwasher ,the breaker is on .
    Problem Solver:
  • 87 Answers
Is it plugged in?
Posted on Oct 14, 2010
Frigidaire dishwasher no power
Hello Tammy, I appreciate your post!
From my understanding your Frigidaire dishwasher has no power. You may need to review your circuit breaker located inside of your home to assure that the breaker has not been flipped. If the breaker is operating properly it could be a possible issue with your control panel or wiring. I would recommend having a professional out to your home to assure a proper diagnosis has been completed on your dishwasher. I hope that this information is helpful to your dishwasher repair. -Matt
Apr 21, 2016 | Frigidaire Dishwashers
No power lg dishwasher
A large dishwasher should have a dedicated circuit breaker in the circuit breaker panel, check to see if the breaker is on, tripped, or off, it should be on. If it is on, remove the panel cover and check for power coming out of the circuit breaker, if there is power coming out of the circuit breaker, check for power at the dish washer. Checking for power at the dishwasher may involve pulling the connector cord if any and check the power outlet for power, if there is no power outlet and the dishwasher is hard wired into an electric box, the electric box needs to be opened and the wires need to be tested for power, involving removing the wire splice nuts or wire nuts. Once the power is verified to the dishwasher and the washer is still with no power, a fuse should be sought inside the dishwasher control panel or that the power feed wires are properly spliced. A voltage testor is needed to test for power. electric shock hazard on live wires, please be carefull or call out a electrician or handyman if power testing skill is questionable.
Aug 11, 2012 | LG Dishwashers
The power went out and when the power was restored the dishwasher did not come back on,whats wrong?
the surge could have fried the circuit board in the dishwasher or maybe the house circuit it's hooked into. maybe first check all of your breakers in your breaker box just to be sure one of them isn't tripped
Jul 15, 2012 | Amana ADB1600AWW Builtin Dishwasher
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
Not getting anypower checked the breaker and that's working fine
you need to check that you have power going through the breaker. you do that with a voltmeter.once you know you have power through the breaker you have to check you have power at the Dishwasher with the voltmeter.if you have power there you could have reset on the motor. or the clock has gone bad.I have seen some feed out of a GFI outlet to the dishwasher.
Feb 26, 2010 | Dishwashers
Turned breaker off then back on now dishwasher has no power
Turn the breaker all the way off again. And then back on again. You should have power now. IF turning the power back on caused the breaker to kick off you may have a short in the breaker itself.
If you are handy you can change the breaker your self for the cost of a replacement breaker, usually under ten dollars. Then you will know for sure that where the problem was or is.
Jul 31, 2009 | Maytag MDB9750AWS Built-in Dishwasher
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
No power to dishwasher?
few possibilities......DEAD-need new one, not connected properly or needs new circuit inside dishwasher. Have you been able to test the power source? Is there power coming from the outlet hard-wire? if si is it the full 120v? Dishwashers require a designated line with a 20amp breaker. Without adequate amp thru the breaker to the line it may not operate to it's fullest or turn on.
May 03, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
