Question about Kenmore 67082 Electric Dryer
When the dryer is running, there is a loud squealing noise. Sounds like possibly a tight or dry belt. Is that possible and how do you solve it?
    Sergeant:
    Champion:
  • 351 Answers
Hi yes there is a belt. may the idler pulley making that noise jim
Posted on Oct 13, 2010
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
NEED HELP, MY DRYER POWERS ON BUT WONT TURN ON TO DRY?
when u say powers on , u mean lights up? but no movement? if so check the thermal shut off thermostat or door switch
Feb 18, 2015 | Samsung DV218AE Electric Dryers
GE Top Load Washer Loud Squealing Noise
Would check belt for tightness and it is also possible you have a dry bearing in pulley, motor etc.
Nov 21, 2017 | GE Profile WPRE6100G Top Load Washer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
It squeals while its running
HI, there are two possible issues here concerning this noise. it is possible that the belt is worn or, a bit loose on the spinning pulley. i recommend inspection the drive assembly. check the belt for possible ware. replace if necessary.
The second problem spot will be a set of damaged drum roller bearings. you will need to totally disassemble the unit to replace these parts.
***most common issue will be bad roller bearings
Jul 08, 2009 | GE Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Dryer doesnt do anything besides a loud noise
What kind of loud noise??  A loud electrical noise??  A loud squealing noise??
It's possible that there is a foreign matter inside the filter chamber jamming up the blower fan.  Pull the filter screen out and look down the filter chamber area and see if there is a sock jamming the fan from turning.  If you can pull it out, that should resolve your problem.  If not, you may need to call a qualified LG technician to resolve this issue.
Mar 16, 2008 | LG DLE2532W Electric Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 67082 Electric Dryer Logo
308 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
