No sound when watching TV or playing a DVD through our Philips DVDR3570H/75 DVD recorder. AUDIO is OK when watching TV with recorder switched off
  • 1 more comment
  • John W Rasmussen Jun 02, 2008
    Hi,Bobby.
    The tv and dvd recorder were purchased 6 months ago and has worked mostly ok. this problem has occurred at least one time before now and We disconnected the dvd overnight (powered down) reconnected it and it worked ok,this was about 4 months ago.We have been away for 4 weeks on vacation and had set the rocorder to program weekly and some nightly programs.On trying to run the recorded programs we have video only ----no sound.
    when switching the dvd off and returning to the TV sound and vision is ok
    Many thanks,BobbyR1234
    I will return tthe DVDR to where I purchased it from.
    I have checked most of your suggestions already.
    I seems like I have got a Lemon.
  •  Bobby
    Bobby May 11, 2010
    Did you have problems with it before? or is this just happen when you recently hooked the dvd player up? The more detailed info you can give the better we can help. thanks
    President:
  • 173 Answers
I would check all cables to make sure they are connected properly and secure, also check the cables for any defects ie bent pins, frays in wiring, etc. and check all connectors on the front or back of your tv (which ever way you have it hooked up) to make sure they are not loose or damaged first. 2. I know you can connect your dvd properly, but I have to suggest it anyway, go back through the manual and make sure all settings are properly set.
3. You may need to update your firmware, which you can find instructions in pdf at this link it will be the 6th link down in pdf. I tried finding your device on the manufacturer's website, but you need the model number, I will include that link as well. Since it only 6 months old, it should still be under warranty so I would check into that as most usually have 1 year warranty. If all else fails, it might be something internal with the dvd recorder and you will have to get another one or take yours to a repair shop, but if you do take it to a repair shop make sure it is one that is reputable and trust worthy. I hope this helps you out and I am sorry I could not be more specific on the problem.
Posted on Jun 02, 2008
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
Ihave philips hdd/dvd player/recorder dvdr3570h/dvdr3590h wehave just had the digital tv switchover but we canot record tv progra
read the instruc. manual since they have information about this matter, if you can or NOT. go to the section troubleshooting for to see and fix it.
God bless you
Sep 27, 2012 | Televison & Video
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
Philips DVDR3570H HDD DVD player Recorder - done basic set up last night but the start up search for analogue channels returned 0 - speant 2 hours re arranging plugs & it still wouldn't locate them? do...
The DVDR3570H will only find analogue channels if you have a TV aerial connected to it.
If you only have a satellite or cable box, then you can still use the recorder, but you will have to use the AV inputs on the recorder. In this case you will only be able to record the satellite or cable channel you are watching.
May 01, 2008 | Televison & Video
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips DVDR3570H for multiregional playing
Hi Dominic,
here is good news for you.
THE philips DVDR3570H CAN BE MADE MULTIREGIONAL .FIRST OF ALL ON THE SET. NEXT REMOVE ANY DISK ON TRAY. OFF THE UNIT AND ON AGAIN.NOW CAREFULLY DO THE FOLLOWING. PRESS HOME,THEN PRESS PLAY/PAUSE. TYPE THE NUMBER 159121212005255 AND PRESS PLAY/PAUSE. OFF THE UNIT AND ON. NOW THE UNIT IS MULTIREGIONAL. i AM A 100% SATISFIED CUSTOMER. THANKS TO PHILIPS.
DR SAJEEV BHASKAR.
Feb 16, 2008 | Televison & Video
Recording to Dvd-rw
yes u hav eto use dvd +r disk ok try that 1st please thx nick
Feb 04, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
