Question about Samsung CLX-3175FN Color Laser All-in-One Printer
How to fix a paper jam in Samsung clx 3175FN printer
  • 5 Answers
SOURCE: Constant Paper jams on CLX-3175FN
Where is the jam happening? Is it right at the print output tray? If it is, where only about 1/3 of the paper will comeout and stop printing, the 2nd paper sensor right about that area is defective. If you're unit is still under warranty, a service call to samsung is needed to get the part replace.
Posted on Aug 16, 2009
SOURCE: My printer is 5 weeks old.
Have you turned the printer off then tiurn it back on. If you have a paper jam, after you remove the paper, you must restart it for it to clear.
Otherwise, if there is paper still in the printer, turn off the printer remove all 4 toner cartridges and the waste cartridge. Once you do that you may be able to see the paper. You may be able to take one more thing out to where you can see the paper better, I am not sure.
Kevin
Posted on Nov 20, 2009
  • 113 Answers
SOURCE: Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Posted on Apr 19, 2010
mariolands
  • 2296 Answers
SOURCE: I have a paper jam
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Posted on Nov 17, 2010
Joed911
  • 4338 Answers
SOURCE: My CLX 3175FN printer continues
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Apr 21, 2011
Clx-3175 laser printer always results in a paper jam -why? how to fix it? Help help please
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
Oct 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I cannot print heavy paper. It consistenly jams. My HP inkjet prints the same weight of paper easily. Suggestions?
The maximum paper weight that should be used on the CLX-3175 is 163gsm, so if you use thicker paper it would jam.
Jun 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Paper Jam 1
there is most probly a pease of paper in side the fuser unit.See if you lift the top cover just under the scanner, the hole top lifts up!!!!!!.in the back you wil be able to see the fuser.Be carefull IT IS HOT!!!!!!!see if you can get eny papers in there.And try to take it out carefully.Otherwise will have to strip it to take the fuser apart to clean it up
Jun 03, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Printer says "scan unit open or paper jam 2" Hav...
Dear
The printer paper jam-2 cover may be opened or not locked properly.
This door is at back side of the printer.
Thanks.
May 21, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I can'r find the paper jam in the printer. screen
If not picking up the paper then it the Pick-up Roller just above where the paper tray is. Remove the paper Tray and Tip Printer back so you can see under the Printer. Take some rubbing alcohol and clean off the rubber roller
Service Manual found here Free...
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Paper keeps jamming when printer warms up on my samsung CFX 3175FN
Hi. can you try to lift the printer and turn it upside down. it is mainly caused by paper clips.
Jan 26, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung color laser MFP CLX-3175FW. Paper jams after the first page is printed and continues to jam each subsequent page. This is the third printer we have tried. Using a MAC computer. Suggestions...
clean the pickup roller that feeds the main tray.
This is an ongoing problem with this printer, even in the single function printers.
I used a toothbrush and water, scrubbing horizontally.
Jul 05, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
274 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
