Question about Toro Lawn Mower With Toro Power Tools
Toro lawn mower starts but won't stay running unless I keep priming it. Toro GTS5 6.0 horsepower.
  • 1 more comment
  • Merv Morley Oct 14, 2010
    Took the bolt out that hold the carb on and holes were clean not clogged.
    How do I clean the idle jet passage
    yes very helpfull
  • 2,926 Answers
The engine is starving for fuel. At this point I am assuming the spark plug is clean and not fouled, and the air intake cleaner is not clogged. The idle jet passage most likely has a blockage, preventing fuel from reaching the combustion chamber. Priming the engine while it is trying to run is forcing fuel to the engine instead of the fuel vaporizing and flowing to the engine.
Posted on Oct 14, 2010
  • GetMeOttaHere Oct 14, 2010
    When you remove the carb, then the bowl. The underside of the carb with the bowl removed you will see a port that runs up to the carb itself, this is the jet passage. Is the spark plug ok and spark correctly when tested?
Toro mower won t start unless sprayed with starter fluid-then runs fine
The carb needs cleaning.. Has the mower been sitting for a period of time ? If so the gasoline evaporates and leaves a gummy "varnish" type residue in the carb.. Gumming up things and making them stick..
Sep 27, 2012 | Toro Lawn Mower With Toro Power Tools
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it...
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Craftsman mower gas leaks into air filter
overhaul the carby , paying to something holding the needle off the seat and flooding the engine
Jan 28, 2018 | Toro Lawn Mower With Toro Power Tools
Mower wont keep running
recycler toro 6hp. 10 years old,little usage. Starts then stops, have to keep priming. Can anyone help?
Jun 14, 2009 | Toro Lawn Mower With Toro Power Tools
My lawn mower will not stay started
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jim
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,775 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
