61 inch Hitachi SD tv. Has been developing an increasing tendency to stop showing its picture, even though the power light is not on. My first thought when it first occurred was that I leaned on the remote and hit the input or something. But no, when I hit the input button, nothing showed on the screen, not even the green input letters. So, I turned it off, and then turned it back on. That had zero effect. The power light was on, but no picture, not even the input letters or the menu. So I tried unplugging the power for a few minutes, theorizing that some breaker or capacitor might drain or reset from a power surge or something. This worked. But, that pattern above has been increasing in frequency, until finally, today is apparently the feared day when the technique no longer worked. So, the power light is on, but no picture. Any ideas?
  • 2 more comments
  • matt885 Oct 14, 2010
    The only one I found was 2200uf 10V, and I could not identify anything weird about them. When you say "vented", the only capacitors that even remotely look weird are these big fat ones on the end which have a white mark which seems like it *might* be designed to display venting along this white marker on the wrapper. These bigger ones are labeled 250V 330uf and there are a pair of them. Is that what you mean?
    Nothing else really looks abnormal.
    Even the fuse looks normal.
    Just to make sure we are talking about the same thing, this is a Hitachi model 69SDX88B made in December 1998.
    There is one thing at the end that looks kinda puffy, bit it doesn't look like the other cylindrical capacitors. But, it still looks like a capacitor from my memory of smaller capacitors. It says 332 J 638 * U. There is another small capacitor at the end of the board that is leaning off to the side, but it seems like it was just put on that way.
    What do you think?
    I am pretty sure that the sound does work, I think it is the picture only, but I cannot tell right now because I have taken the power board out to check the capacitors. Just so that you know, what I was checking was for a puffy, blown out or venting capacitor.
    I only saw one on the board that looked "puffy" but I don't know if that was the normal state of the capacitor or not, but none of the capacitors that look like cylinders really look bad in any way, but I'm not sure what "venting" would look like.
    Thoughts?
  • matt885 Oct 15, 2010
    Do you happen to know the board positions of those components? I am trying to find them, but I don't read anything that sounds like the IC's you mention. Or, if you like, perhaps you can indicate on the linked picture?
  • matt885 Oct 22, 2010
    How exactly do I check the controlling IC with a voltmeter? what should it read? I'm not an expert on electronics, I have done a few things over the years, but nothing super-serious.
  • 11,800 Answers
Yes, it's exactly what you thought - the power source no longer delivers the high tension. And since it has been a progressively worse problem (and not a sudden one) it's surely capacitor related - they have aged . BTW by aged i mean that their capacity and their insulation performance has decreased. The deformation or leaking is the absolute last step in their situation, when they fail completely.
You will gonna have to replace them all and check all the solderings on the power board.
Posted on Oct 15, 2010
  • Azrael SRL Oct 15, 2010
    The 2 big black round ones(top right) and all the ones with a silver tip and an Y stamped on it - those are the capacitors.
    The controlling IC is the one that is bolted on the radiator at the top left. You should check it using a voltmeter.
  • Azrael SRL Oct 22, 2010
    With a simple voltmeter you will get just a very basic idea if it works, not how well it works: check that it powered (5v) and that the output pins have some output on them - around 3v for an average image.
  • 4,889 Answers
You did not tell me whether you have sound or not? Please provide this info so that we can continue troubleshooting.
Sai.
Posted on Oct 14, 2010
  • 5,138 Answers
Bad Capacitors on Power Supply Board they will be swollen,vented or puffed up on TOP 2200uf 10v 3300uf 10v 1000uf 16v. Radio Shack should have these caps.
  • ladywinn
    ladywinn Oct 14, 2010
    OK,wrongTV ,If its a 98 model you have 2 STK ICs will have PN# on them STK392-110
    Replace Both ICs , use 120s or 150s Check all the low ohm resistors around these ICs
    Mats Electronis sell them 1-800-628-1118 Check Pico Fuses they will look like resistors but they are Green or Yellow 5amp,6amp.7amp Fuses
I have the 61 inch, and the color looks like it's bleeding into each other, kind of like a 3-D show, it's not as bad as that though, how do I fix this problem?
You need to locate and replace both of the two convergence chips the set uses. Most likely they will be STK-392-110 BUT THE NUMBER WILL BE PRINTED ON THEM IN WHITE.
total parts cost if you can do it yourself will be under 30 dollars.
I will attach a photo of typical chips for you.
Dec 27, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi model 60v500a.the middle of the screen is a little yello
If you Google "60v500a light engine" you will learn a few things about this set which was first sold in 2003.
There are some class action lawsuits out there for several Hitachi models made at about the same time.
Most of the time these sets develop a discolored area fairly large in the middle of the screen---a lot of them had a large red or pink oval area but other colors are possible.
This set uses a LAMP for the light source and it directs the light into the optical light engine--at the top of the engine is a 3 inch lens that the picture comes out of and is directed into the mirror which puts it on the screen.
Lots of these sets develop a "burn" inside the engine from the heat--there are a series of lens and baffles inside---even slight separation inside will change the color in some area of the picture.
I am sorry to give you bad news but I have replaced a lot of these engines under extended and when they were new mfg. warranty.
The part is no longer available from Hitachi new--the only way to get one is to remove the one in the set and have it sent out for "rebuild" and the last time I saw one the engine was over 600 dollars at the wholesale level not counting the fact that it is major labor to replace.
Find someone in your area familiar with Hitachi and this model and you will see what I am talking about.
Even though this is not good news, I think it is what your problem is.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Hitachi 60V500 60" Rear Projection...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi projection tv was turned on and off repeatedly by child
sounds like you have lost the power supply , probably high voltage. That is what drives the tubes. Your low voltage is working because you have audio.. Proably not an in home repair. Good luck
Jul 09, 2009 | Hitachi 61SWX10B 61" Rear Projection...
I have a Hitachi 50v500. It has a bluish tint like a cloud in the center of the picture that started out small and has gradually increased in size. What is this and can I fix it myself?
The Light Engine is the problem and a major tear-down. It is not a customer replaceable part. Cost of the part is around 850.00 to 1000.00. then you got the labor cost on top of that. Unless Hitachi is willing to help with repairs I would not even consider spending the money. It never hurts though to call Hitachi and see what they would do to help.
Hope this helps,
Skyassoc
Jun 28, 2009 | Hitachi 61SWX10B 61" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
No audio, no video
Can you find out what Led is not on or which comes up and goes out? Most of these sets have convergence problems. Or Power Regulators.
Sep 23, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
