Question about Pool & Spa
Heater doesnt stay on and only goes on when the jets are running
  • 990 Answers
This could be a water flow problem. You should check to be sure the filter is clean and the baskets also. Then check the impeller on the pump. If you have two pumps find which is low and check the plumbing to be sure it is clear. Also if you have had it drained and it's above ground you will need to open the drain to flood the pipes. Good luck.
Posted on Oct 14, 2010
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Heat pump does not work
can some one help me i have a spa quip sq1500 and my heater light will stay on for say 5 or 10 min but soon as i put jets on again the heater will go off and stay off untill i turn off jets again ????
thanks
Jun 08, 2013 | Pool & Spa
Older spa spa quip sq1500 need replacemnet control box model 2095bb5 and heater element
thanks
Jan 19, 2013 | Pool & Spa
I have a 1999 Laser Select hot tub. It gets ups to temp but when we get in the temp goes down pretty quickly
Does this happen when you're running Jets and/or Air Blower?
Using an air blower w/o an air heater or opening all the air controls for bubbles will cool the water rapidly.
The solutions are to get an air blower with a ceramic heater on the intake. Avoid using the venturi style air controls.
As heating and filtration are done on the pumps low speed you could change the control box to a high current setup where the heater will stay on when the jets are high. This is not possible on all controls & should only be done by a technician.
Hope that helps
Dec 01, 2012 | Home
Our Jandy LX400N does not show any error messages but the water that comes out of the jets is intermittently hot, then cold. I have never heard of a hot tub problem like this. Is there a way to just have...
check gas pressure maybe running out of gas then it goes out then relites check to see if heater is running continuously bad manual bypass replace it by the plumbing in and outs
May 23, 2011 | Jandy Laars Lx 400,000 Btu Heater
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Atwood water heater light doesnt stay on
That light in the switch should only be on momentarily while it is igniting, and then go out when everything is ok. If light stays on, it's to alert you that for some reason, the burner did not ignite, such as propane is off, or some other reason it didn't ignite. If the light stay out, then the burner should be working properly.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
HEATER IS JUNKY
Sounds like you have a blockage to the main jet. If you have a compressor just blow the jet out from the top and with a bit of luck it will clear it. If not you may need to remove the outer covering and find the pipe to the main jet and again using compressed air just blow it out. Usually not much goes wrong with these apart from blockages every now and then and most of the servicing places just blow them out with compressed air. Just make sure if you remove a pipe you tighten the pipe up properly when re-fitting it. Hope this helps.
Regards
Bryan
Dec 27, 2007 | Heating & Cooling
My pilot light won't stay lit. As soon as I lift the button, it goes out.
Sounds like you have a blockage to the main jet and maybe to the pilot light. If you have a compressor just blow the jet and around the pilot light area out from the top and with a bit of luck it will clear it. If not you may need to remove the outer covering and find the pipe to the main jet and again using compressed air just blow it out. Usually not much goes wrong with these apart from blockages every now and then and most of the servicing places just blow them out with compressed air. Just make sure if you remove a pipe you tighten the pipe up properly when re-fitting it. Hope this helps.
Regards
Bryan
Dec 09, 2007 | Dyna-Glo (PPH16-LP) Utility Heater
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
