Where do I put lubricant( & what type of lubricant) on an office chair that now squeeks & moves down without warning. I bought the Samsonite chair from Costco in 8/1999. It is model 1908HE. Judy Mette
    Genius:
  • 1,218 Answers
What does this have to do with FAX machines.???
Posted on Oct 18, 2010
  • Anonymous Oct 18, 2010
    Is this causing a problem with your FAX machine...I dont understand.
Why doesn't chair remain at desired height?
Failure of the height adjustment mechanism
Feb 16, 2016 | Furniture
Why does it make a crunching noise?
Your chair is NEW! So, return your chair to the store where you bought it and complain!
Aug 01, 2015 | Furniture
What is making creaking squeeking noises in power chair?
hi, that noise can be caused by the seat mount moving slightly within the seat holder, because it 's a tight fitting when it does move slightly , you get the noise...only needs mm amounts of movement, Careful spraying WD40 in the gaps will solve this but take CARE making no electronics or electrics are near...disconnecting one battery will be ideal..
a visual inspection of all of the bolts and nuts should prove peace of mind...
WARNING: You need to tip over the power-chair to carry out the instructions set out below so extreme care is required.
This noise can also be caused by the motor gearbox ,, carefully place your hand on the gearbox as someone powers the chair , can you feel a grinding sensation ? , bear in mind you will get some feeling there of a dragging.
Regards
Rob
www.gewizrepairs.co.uk
Oct 10, 2014 | Pride Mobility Jazzy 614 - Jazzy Blue,...
Office chair seat will not stay up, keeps sinking
The sinking seat is a common failure mode of this type of chair.
Apr 01, 2014 | Furniture
At what stores can I buy office chairs?
Hey I have designed my office just few days before, and its looking awesome and i have purchased office chairs and Office tables from http://www.expressofficesupplies.com/. I am pleased with shopping on that site which having modern and fashionable Designed products. Happy!!
Jul 30, 2012 | Furniture
What is an office chair?
An office chair is a type of chairs which designed to used in Office.Sunview Seating Solutions specialize in Manufacturing all kinds of Office Chairs in Delhi
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
How many levers do office chairs have?
Office chairs usually have two levers. One is used to raise and lower the seat. The other lever is used to determine theangle of the back rest.
May 29, 2012 | Furniture
I have pyramat chair where do i run rca cables from
How to Connect a Pyramat
Pyramat gaming chairs are high-end video recliners that integrate audio speakers and subwoofers to increase video game immersion. Pyramat chairs feature speakers and woofers placed at the head and elbows of gamers for a surround-sound effect. The chairs come in two types. Game chairs are similar to regular computer or office furniture. Gamebags are reinforced beanbag chairs with installed speakers and controls similar to the game chairs. Each of these must be connected to the console or computer to run properly.
Instructions Things You'll Need: Pyramat game chair or gamebag 12-volt AC adapter 3.5 mm audio cable 3.5 mm RCA audio adapter 1 Close all programs and power off the computer or console that you are connecting. Power surges or connection problems could cause damage to the devices if still plugged. 2 Connect the 3.5 mm audio cable to the control area on the arm of the chair or side of the gamebag. 3 Plug the other end of the 3.5mm audio cable into the stereo jack on the computer or console. Use the RCA audio adapter if the console has only A/V cable support. 4 Connect the 12-volt AC adapter to the chair and insert the other end into a grounded power outlet, preferably one with a surge protector. 5 Power on your game chair or gamebag using the control and turn on the console or computer. 6 Adjust the sound settings on the chair and your video game device to suit your preferences.
Tips & Warnings Do not get your game chair wet as this can damage the speakers and controls.
All necessary parts should be included with your game chair. If it is missing anything, contact Pyramat customer service for replacements.
Mar 07, 2011 | Pyramat Sound Rocker Gaming Chair
80 people viewed this question
k24674
jasbo
jasbo
