I have a Sylvania TV CT202SL8. I need the closed captioning. I get it OK for regular TV channels--but NOT when using DVDs. I don't even know whether it's supposed to or not, and I've lost my owners manual.
  • somdbob Jun 02, 2008
    Re. the Sylvania problem--this does NOT involve projection TV..
  • somdbob Jun 03, 2008
    The manual was for my model--but did not lead to a solution. I was hopeful that the steps described on pages 20-21 would do the trick, BUT the items shown under TV/VCR Setup had a problem--i.e., the key item needed is 'DTV Setup' and it is the last i.e., lowest item listed. The next lowest is Index Search--which is The lowest on my set. In other words, without a "DTV Setup" you're nowhere.
    I've contacted Sylvania's tech people re. this, along with serial number and date of mfg (3/07)--but no reply as yet. I consider your input as still working but not yet resolved.
    Genius:
  • 3,422 Answers
Please CLICK HERE to view the user manual.
Goodluck..
Posted on Jun 02, 2008
  • Priya darshan Jun 02, 2008
    OK so you mean the owners manual which i gave you did not help?Or is the manual not for your TV model?
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Why does a black box keep appearing on my screen?
The box is probably because you have closed-captioning turned on and set to "text" mode. Check the TV remote control for a button marked "CC" or "CAPTION" or something similar. Press the button to cycle through captioning options until you get to "OFF". This should clear up the trouble.
What's happening is that in text mode, the TV blanks out the area on the screen where the text should go, but there's nothing to display. Text mode isn't widely used, but in some markets it's used to display weather or other information. What sometimes happens is that the caption button on the remote gets pressed and you don't know the TV is set to text mode until the box starts coming up. And it doesn't happen on every channel, or even all the time on the same channel, so it can seem very random.
Thanks for using Fixya!
Oct 06, 2010 | Sylvania SRT2232S 32" TV
Samsung LCD tv no sound from one channel only, no cable box, direct connection to cable, worked ok and then somebody may have fooled around with closed captioning...no closed captioning on now, but no...
First try viewing regular programming and see if you have audio on both channels. If you do not then go to the user menu and make sure that the chim function is turned "on". Then turn off the tv and listen for the down chime coming from both speakers. If you only hear the chime from one speaker then the Aidio circuits are bad on the Main bd and needs to be replaced.
Jul 13, 2009 | Samsung LN32A330 32 in. LCD TV
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
Toshiba TV 32AV502U - closed captioning
if you have satalite or a cable box the settings need to be changed in them for CC
Jan 08, 2009 | Televison & Video
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Can't get closed caption when i'm playing a DVD
The DVD player needs to have the decoding built into it.
Sep 18, 2007 | Sanyo DP42746 42 in. Plasma Television
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Closed Captioning
I it was sold In the US it HAS to have the opyion of closed caption as to the Americans with Disabilitys Act(ADA). It has to be in the manual somewhere. Contact 1-800-968-3429 Good Luck
Aug 17, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
